What size hydraulic lines for plow to FEL
   / What size hydraulic lines for plow to FEL #1
toofastLS
CT
LS 4041
I recently purchased an LS4041... with winter knocking i have begun fabricating a mount to attach my fisher 7'6" to. My question is the hydraulic lines which were installed for my 3rd function grapple are massive est 1" diameter the old fisher lines are at least half the size. Is it ok to use the small lines for the plow with an adaptors to allow connection of the large quick couplers. or would I be better off using the same large lines the grappel uses and reduce at connection to fisher rams?
Sorry typing from a long night shift and I dont have psi or actual line diameters in front of me.
   / What size hydraulic lines for plow to FEL #3
Rick is 100% correct as usual, anything larger than 1/4" is a waste of money and real estate.
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
