What size fire Extinguisher???
   / What size fire Extinguisher??? #1
chico922
Rockford,IL
John deere 755
I read about a grage fire now i worried about my grage. This person was working on his car when it backfired and set the car on fire. His fire extinguisher wasn't big enough to put it out. So what size do i need for my grage? I have a 30' X 46' stell pole shed. I keep 2 cars, tractors, gas cans, ect. I also have a solvent tank but i'm not worried about that. It's on a fire proof tank. I have a 3 pound Extinguisher now but I want to make sure it will do the job.
chico922@excite.com
   / What size fire Extinguisher??? #2
If your garage is anything like mine, you have quite a variety of substances located throughout the building. I think the minimum size you should have is a 10 lb. ABC extinguisher, although a 20 lb. would be better. Or get two 10 lbs. and have one on each side of the garage. Since you seem concerned about having one large enough to do the job, get the largest you reasonably can to make sure you have enough. Any of these should come with brackets to use to mount on walls. The 10 lb. units might run anywhere from $40 - $70, depending on where you get them and the make. the 20 lb. units will go for $80 - $120.
   / What size fire Extinguisher??? #3
I worry about fires in my garage too. I've talked to firefighters in the past and their recommendation was to have appropriate rated fire extinguishers mounted near each exit. For most garages, that would be a minimum of two with one near the big door and one near the small door.
I never work with flammable metals, so a extinguisher with an ABC rating is all I need. This gives me the ability to put out anything that might burn in my garage. I don't recall exactly, but I believe the extinguisers I have are rated "10A1BC" dry chemical. I also check the pressure gages regularly and turn them over and tap the bottom of the extinguisher with a rubber mallet to loosen up the dry chemical.
Several years ago (ok, many years ago), we had the fire dept over to do extinguisher training and it was very enlightening. We lit and put more fires out in a day than the typical person will see in their life time. The fire chief brought over all kinds of fire extinguishers for us to try and all of us got to put out several fires. It was a lot of fun and we got to see how choosing the wrong extinguisher could actually make things worse. I got to try halon on a gas fire and it blew gas all over and then I got to use an appropriately rated extinguisher to put out all the little fires I started.
One last suggestion. Stop by your local fire dept and talk to the chief and see what they recommend. They may even offer some training for homeowners once in awhile. Sorry for the long winded post, but it all seemed relevent to your question.
   / What size fire Extinguisher??? #4
chico922
One of the first items that a boating class teachs is to have enough Fire Extinguishers.
Second is to have them located in a place that will allow you to get away from a fire, but still have access to a Fire Extinguisher.
I bought my latest fire Extinguisher at West Marine. They have a double set of 10 ABC for about $34.00.
Check them out here.
Click Here
   / What size fire Extinguisher??? #5
Get the largest one that the people using the garge can carry, this is usually a 20 lb'er. The rating 1 A- 10 B,C is common, it just reflects the fact that dry chem extingushers are poor on cellulose (wood paper cotton) fires compared to water.
If you work on newer cars a lot, consider a CO2 extinguisher. You need a bigger one to control a given fire but you won't ruin the insulation on the wiring harness.
Ken
   / What size fire Extinguisher??? #6
alot of good info here, but what ever you do, buy enough, then buy a couple more next time you see them on sale. in our machine/welding shop, there's one everywhere you look. chemical, c02 and h20/foam (one i borrowed from the firehall). and last but not least, there's always atleast one pail of water sitting next to the welding bench.
if you start a fire, when you turn to run away, you should be able to grab an extingusher.
   / What size fire Extinguisher??? #7
You are a wise person to be concerned about this subject. Several others who replied to your post mentioned 10 and 20 lb. extinguishers, which I feel is a misleading term. What is of greater import is the rating of the extinguisher itself. The 1A10BC units are the smallest commonly available and most weigh between 3 pounds and 3 1/2 pounds when filled. Their ABC rating means they can be used for all types of fires and the size is practical to keep in a kitchen or carry in a vehicle.
The next step up would be a 3A40BC unit which weighs between 7 1/2 pounds to 8 pounds when filled. These models are the minimum size you should keep in a garage, basement shop, or pole barn. They have roughly 3 to 4 times the fire fighting power of the 1A10BC units. If you have flammable liquids stored in an outbuilding it would be cheap insurance to have more than one extinguisher nearby. I have lived in the country for 15 years and never needed any of the multitude of extinguishers I have throughout the house and garage and barns, but if I ever need one, I will have it ready.
Interestingly enough, my homeowners insurance provides a discount on my $1400 per year policy because I have multiple extingishers around the premises. My agent tells me that although deadbolt locks and smoke detectors are also a factor, the fire suppression equipment is the main reason his company grants the discount.
   / What size fire Extinguisher??? #8
I have 20 pound extinguishers at each door (walking and overhead) and I have them in several other places. JMHO but 4 extinguishers minimum for a 3 car sized pole barn. Knowing the ratings is a good thing too. Having a soda/water extinguisher in a garage where it is likely there will be an oil or chemical based fire is totally useless. Most of my extinguishers are chemical extinguishers, but I do keep one CO2 extinguisher as well.
   / What size fire Extinguisher??? #9
Halon on a gasoline fire, outdoors....no wonder it did so poorly as halon is intended to be used only indoors or in confined spaces.
It is one of the best fire suppression agents available but is of practically no use when sprayed into open air. The EPA would also take a very negative view of that use... as halon was claimed to cause problems with the ozone layer-- I think production was curtailed back around 1995. To my knowledge it is still legal to purchase and use the product but a 1A10BC halon extinguisher costs about $245.
   / What size fire Extinguisher??? #10
Had a Halon system installed on an I/O pontoon boat years ago that I owned. It was a neat looking system and I was fortunate enough to never actually need to use it. So I can't tell you how effective Halon actually is as far as extinguishing a gasoline fire. It came to me highly recommended at that time.
2013 PETERBILT 367 (A45046)
2013 PETERBILT 367...
2017 Hyundai Sonata Sedan (A42744)
2017 Hyundai...
2021 Chevrolet Tahoe FL SUV (A42744)
2021 Chevrolet...
50 Gallon Fuel Tank (A42021)
50 Gallon Fuel...
2007 INTERNATIONAL PAYSTAR 5900i DAY CAB (A43004)
2007 INTERNATIONAL...
2018 CIMC VEHICLES GROUP CO CHASSIS TRAILER (A45046)
2018 CIMC VEHICLES...
