What size finish mower for my size tractor?
   / What size finish mower for my size tractor? #1
new2diesel
Saybrook, OH
Farm Pro 2420
I am wondering what the largest finish deck I can pull behind my 20HP 2cyl. diesel? I was thinking 60". Is 72" too big for this size tractor? Thanks in advance for your responses.
   / What size finish mower for my size tractor? #2
My first tractor was a 21 hp 3 cyl diesel and the dealer set me up with a 48" mower. The same tractor will pull a 54" mid mount mower no troubles. Sixty inches may strain it a bit if you don't have low gearing.
See this site:
TractorData.com - Mowing with tractors
   / What size finish mower for my size tractor? #4
I think you'll be fine with a 60"mower.
Will
   / What size finish mower for my size tractor? #5
60 inch should be fine. 72 would probably be a little much.
   / What size finish mower for my size tractor? #6
I have easily pulled a 5' REAR DISCHARGE finish mower with a FORD 1210 (16hp, 13hp PTO). My new to me Mahindra 2015 gear (20hp, 18hp PTO) man handles the same mower.
   / What size finish mower for my size tractor? #8
If you are just mowing grass it doesn't take a lot of HP for a mower. When you start getting into the 72" or plus size mowers the weight of the mower should be taken into consideration. My 30HP Kubota is only rated for a 500 pound rear mower. My 72" mower weighs 719 pounds. Although my Kubota powers this 72" rear mower easily I am pushing things quite a bit with this much weight on the three point.
   / What size finish mower for my size tractor? #9
I have a 24hp (at the engine) yanmar 2cyl. I can run a 72" mower on it but its all it wants. Now if you cut your grass weekly you could prolly get buy with a 72"er but for me its weeks often months and i have to drop a gear and take 5ft bites to keep the mower speed up.
   / What size finish mower for my size tractor? #10
I dont think they put a limit on what the yanmar can lift on the back like that. They give your lifting limits like were your releife will pop on the three point but i dont recall seeing anywere to keep a weight to a certain amount. Maybe cause its old and a grey model? But if it can lift it the tractor should be able to handle it or else they would set the releife lower you would think.
2009 Kenworth T800 Truck, VIN # 1XKDP4EX69J245973 (A44391)
2009 Kenworth T800...
CAT 924 Wheel Loader (A42203)
CAT 924 Wheel...
2021 Chrysler Voyager L Van (A42744)
2021 Chrysler...
2022 Ford F-550 4x4 Ext. Cab Forestry Dump Truck (A42742)
2022 Ford F-550...
2019 CATERPILLAR 303.5E2 CR MINI EXCAVATOR (A45046)
2019 CATERPILLAR...
14ft HiWayStar T/A Enclosed Cargo Trailer (A42742)
14ft HiWayStar T/A...
