What size FEL to buy?
   / What size FEL to buy? #1
Anonymous Poster
Epic Contributor
HI, I am looking at getting a 2210, and there are 3 different size buckets that are available:
49" 53" 61"
There is not much of a price difference between the 3 so that would not be a factor in deciding.
I will be using the FEL for snow removal other light work around the home.
Any input would be great.
Thanks.
   / What size FEL to buy? #2
If you are removing snow, you need a bucket that is wider than your tractor tire treads to clear the way. You will have better traction, and not compact the snow by driving over it.
   / What size FEL to buy? #3
A YM2210 can handle a 61" bucket in snow & other light work.
   / What size FEL to buy? #4
I asked a similar question a while ago, <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=216525&page=2&view=collapsed&sb=5&o=0&fpart=>FEL owners - what size bucket?</A>. The general opinion was to get a bucket the same width as the rear tires.
   / What size FEL to buy? #5
If your uses are anything like mine you'll find yourself using your FEL more on things of bulk rather than on items of weight. With that in mind, I'd suggest the largest capacity bucket you can get (61" in your case).
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2001 XL SPECIALIZED XL 80 MDE DOUBLE DECK TRAILER (A53426)
2001 XL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
