What size engine do I have?
   / What size engine do I have? #1
Ghost Rider
Butler, A:
Ford 4150
I have what I think is a 4140 tractor. It's buff/blue in color. It has a bucket on the front model #712. By the starter is a hand stamped number b50 under that is <>4921<> .The rear-end is CONN4024F on the passenger side I found the # 310809 The transmission is NDA7006B Ane the rear axle has the number CONN4012E. With those numbers can anyone tell me for sure what type of tractor I have and what size engine is in it. The engine is a 4 cylinder diesel and the pistons are 3 7/8" wide. Appreciate any help I can get as I have to rebuikd the motor.
   / What size engine do I have? #3
There should be a model code and serial number somewhere around the starter.
   / What size engine do I have? #4
Those #s you list by the starter are probably them, by just don't seem right.
I know tractor data.com isn't all inclusive, but they don't list a 4140. What leads you to believe that is what it is?
   / What size engine do I have? #5
look onthe bellhousing flat by the starter again.. there will be a model ID code and sn.
   / What size engine do I have? #6
Could it be a 1954 - 650 (b50) ????? Pictures would help some. If it is it would be a 134 cid.
   / What size engine do I have? #7
those dont have 3-7/8" pistons
   / What size engine do I have? #9
i missed it too.. I just looked at the pics.
if it is a diesel.. it's a 59+ model meaning an 01 model.
and that also means it's only options are 144ci and 172 ci
The reason I think it's a 4140 is that, from what I have found out, a 4140 and a 1801 are the same except the 1801 has cable steering and the 4140 doesn't. So far I think mine is a 4140 HD Industrial tractor, The bucket is a Model 712. Think it had a back hoe because there is no PTO shaft. Found a # on the engine block 310609 which I think shows it's a 172 diesel. The piston sleeve is 4 1/4".On the transmission is # 7006B. Not sure what that # means but it is a 5 speed. (4-2-3 up 5-1-R down) The rear axle is marked CONN4912E and the rear-end is marked CONN4021F. Checked the motor again and all I can find is, behind the starter is either b50 or 650. One book said they used the "b" as a "b" "6" or "9". below that number is <>4921<> . The bucket was yellow but painted over blue, The tractor is blue with gray fenders. Thanks for the advice and comments. With your help maybe I can figure out what it is. Thanks again Ron.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
