3-Point Hitch What size disk for a l4200
   / What size disk for a l4200 #1
fastback88
Bronze Member
Sturgeon Bay WI
Kubota L4200gtsc,LA680 loader
What size 3pt or pull type disc can my kubota l4200gstc 4x4 with fel and ag tires pull. I will be using this along with a 6'S tine 3pt drag and 6' boxscraper to maintain a motocross track.
I have a 5' cheep kingkutter disc, (which I have not tryed yet came with the tractor when I bought it this winter and the frost is just getting out of here) but I don't think it will hold up using it on the track and it is not wide enough I need it wider than the rear tires atlest.The ground in mostly black dirt with a small area of clay mix. Which would be better 3pt or pull type I have rear hyd ,so I'm guessing the pull type with wheels would be my best choice but how wide?
   / What size disk for a l4200 #2
Many choose three point when buying new do to the reduced cost! I would think that anything 8' or less would be good.
Thanks, anyone else? The tractor is 45hp.
   / What size disk for a l4200 #4
You say this disc will not be used for agricultural purposes but rather for track maintenance.
So, consider a pull type disc of maybe 10 feet or less. :)
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
