What size bush hog : wide as or smaller ?
   / What size bush hog : wide as or smaller ? #1
BWa
Brockton / West Bridgewater Ma.
2002 JD 990
I have a JD990 ( 40hp / 35 hp PTO 1500lbs lift at 24" )and have found I really do need a bush hog ,,, but what size ? I am looking at heavy duty that is a given ,( I have not decided on what brand or model yet ) so for example given a choice between a 5' wide MX or a 6' MX what would be the best choice for this tractor and first time user ? If these are not a good fit then how about the LX series 5' and 6' models ...
Thank You
Bill G.
/forums/images/graemlins/confused.gif
   / What size bush hog : wide as or smaller ? #2
I hate to be the master of the obvious here, but, if you're looking at a Deere cutter for your Deere tractor, why not ask Deere?
   / What size bush hog : wide as or smaller ? #3
According to Deere it's the MX5 or the LX6 if you want the lighter duty but bigger size. Check it out at JD attachments
   / What size bush hog : wide as or smaller ? #4
Both the MX5 and the MX6 will work fine given your PTO HP. The MX 5 only needs 25 PTO HP, with the MX6 coming in at 30 PTO HP. As to which one is best, that would depend on how many acres you are mowing, how much time you have, how much money you have, how many trees you have, how many... you get the picture. /forums/images/graemlins/grin.gif
I think I recall my dealer telling me that at 4 mph it takes a 5 foot cutter 2.5 hours to cut 5 acres, with a 6 footer coming in at 2 hours. Not much difference if you're only cutting 5 acres, quite a lot if you're cutting 100. /forums/images/graemlins/tongue.gif
   / What size bush hog : wide as or smaller ? #5
I would agree, according to his PTO HP he should be fine with an MX6 but JD... the people who will be warrantying his tractor disagree /forums/images/graemlins/grin.gif
They list ONLY the LX6 and MX5, they do not list a 6ft medium duty cutter.
   / What size bush hog : wide as or smaller ? #6
I was torn between getting a 5' which would cover my track and something smaller. I have a 30HP [22 pto hp] Kubota B2910.
In the end I bought the 5' woods bb 60.
I have only limited use so far but I am pretty sure I made the right decision.
So my vote would be to get one that covers your tracks. Nothing narrower than what your rear wheels measure at the widest point....
Right or wrong...that is the way I now feel after getting and using the one I have...
   / What size bush hog : wide as or smaller ? #7
<font color="blue"> ( a JD990 ( 40hp / 35 hp PTO 1500lbs lift at 24" ) </font>
Your 990 will drive the MX6... but your main limitation will be controlling its weight of 1000 + lbs. danging off the 3-pt. hitch... (also considering your 3-pt hydraulics relief valve set @ 1500 lbs. lift capacity)
See if you can hook up a 6' unit and test it for geometry's sake... (but still not as good as real life testing, as in side-hilling and inclines doing actual cutting) /forums/images/graemlins/smile.gif
   / What size bush hog : wide as or smaller ? #8
</font><font color="blue" class="small">( I would agree, according to his PTO HP he should be fine with an MX6 but JD... the people who will be warrantying his tractor disagree /forums/images/graemlins/grin.gif
They list ONLY the LX6 and MX5, they do not list a 6ft medium duty cutter.)</font>
I haven't seen the tractor brochure. The JD Rotary Cutter catalog for the MX, HX, and CX series cutters only lists the PTO HP required. Weight of the unit matches the original posts specs, so I based my comments on that. I did just notice that the MX6 is shown with a Cat 2 hitch - so maybe it's NOT the best choice. /forums/images/graemlins/tongue.gif Then again, what do I know - my tractor's Orange! /forums/images/graemlins/grin.gif
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2014 Kubota M8560D (A53317)
2014 Kubota M8560D...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
