What size bush hog for a 5570?
   / What size bush hog for a 5570? #1
IH4739
Erin
Mahindra 5570
What size bush hog will a 5570 handle? I want to go as big as I can without overloading the machine. Also what is more important the horsepower or the weight of the tractor
   / What size bush hog for a 5570? #2
You can easily operate a 10' pull type bush hog or a 12' bat wing. Lift types are another story but you should be able to lift a 7'. Weight and hp are both important and the 5570 is a well balanced machine. If you bush hog any slopes, I would encourage you to set the rear track as wide as possible.
Your right it's much safer to have it set out wide. I have found a pretty good deal on a 15' cutter is why I was wondering about what the 5570 could handle. Maybe I should get the 12' I'm afraid the 15' would just be too much
   / What size bush hog for a 5570? #4
I think someone on here once said something like this: Weight gets the work done, horsepower gets it done faster. I also recall a recent post from someone who had a heavy Mahindra that was in the 40-50 hp range that struggled with a 7' cutter going up a hill. Don't know if there was a problem with the powertrain control module or if the tractor was simply overloaded.
   / What size bush hog for a 5570? #5
General rule of thumb is five pto HP per foot of cutter. That being said there are different scenarios to consider. Flat or hills ? maintaining pasture ? or trying to reclaim thicker denser brush area's..I personally use a 10 ft drag hog to maintain my pasture with no problem. with my 35 HP pto .Granted I have to cut in a lower gear,but the wider cut at a slower speed versus narrower cut at a higher speed are a wash in my mind.The thicker area's grown up with brush, I drop drop to my six footer ..Your 5570 I believe has somewhere around 62 pto hp or so if I recall.
Rule of thumb say's 12 ft, It would probably run the 15. You may check the hp requirements on the hog you are looking at if they are available. I have found that each manufacturer can at times have wide variations on their HP requirements.
Regard's
Sean
   / What size bush hog for a 5570? #6
Don't forget about the weight factor of the tractor. I had a 5545 that would almost stall a 5' bush hog on a very steep grade low range 2nd gear in tall grass.
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
JLG 1255 Telehandler (A52748)
JLG 1255...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
