What size brush hog?
   / What size brush hog? #1
djg
western wisconsin
kubota B6200HST-D
I just bought a 15HP Kubota 4WD tractor. It has 12.5 PTO HP. What size brush hog can it handle? I need to mow 2 acres of neglected farm field that is now the back half of my lot. Thanks for any advice.
   / What size brush hog? #2
David, I think (not absolutely sure) that Kubota recommends only up to a 42" brush hog; however . . ., what kind of growth does that neglected field have? Just weeds and grass? Small saplings? 1", 2", 3" diameter. Personally, I'd probably go with a 4' (48") brush hog. If the growth is too heavy, overlap more; i.e., only cut half or two-thirds of the mowers width at a time, or simply drive slower. I used a 4' Bush Hog brand on my B7100 with 16 engine and 13 PTO hp and usually cut full width at a time.
Bird, that's what I thought, based on my studies here at TBN. There is this nice looking 60" hog on Ebay that looks like it will go pretty cheap and is real close by, but I guess it is just too big for me. I hope to put in prairie type plants in the field after I clear it, and these require a yearly mowing. Right now there are some small trees, mostly evergreens, and 2' weeds. I was hoping to uproot these trees if my tractor will do it. Do you have any thoughts on that? Thanks.
   / What size brush hog? #4
Yeah, David, I'd not want a 60" brush hog for that tractor. As for uprooting small trees, it just depends on the type of tree (or rather type of roots) and type and moisture of soil. I've been surprised by how easy some came out and how hard others were to get out. I have pulled a few with a chain or cable, I've pushed some over with the front end loader 2 or 3 feet off the ground, then backed up and put the bucket under the roots and pushed forward and upward at the same time and took them out that way, and some just simply defied my efforts.
   / What size brush hog? #5
Hey David,
I have a Ford 1220 that I'm running a 4 foot King Kutter Brush Hog on. I really wanted to buy a 5 footer and the guys at TSC suggested I COULD probably handle it, but I went with a 4 footer. It was a better choice for an 18HP tractor.
I bought a Woods RM59 finish mower but was really lusting for a 72 inch, the 60 inch was a better choice for the 18HP Ford. It discharges the grass a mile, the 6 footer, well, I don't know, I haven't tried one yet....
This is probably a poor generalization but....
The 5 foot hog covers 20% more ground but the 4 foot hog has 20% more HP to do the same job....
I have this belief that any implement you buy at the right price, can't be a mistake, someone else will always be willing to take it off your hands!
Good Luck to you!
Curt
Thanks for your help. I will wait for the right one to come along.
   / What size brush hog? #7
I have a 6' towable Swisher that I used to use with a bigger tractor. With my 18 hp (pto) I can start the blades or the tractor, but not both at once. You might get a 5' spinnin' usin' that method, but it's tough on the tranny. /forums/images/graemlins/tongue.gif
   / What size brush hog? #8
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
