Tractor Sizing What size belts (MT372 with 50" Haban)
   / What size belts (MT372 with 50" Haban) #1
MT372HERE
My Mule drive belt jumped off tonight and shredded itself on the mule pulley arm, parts were flying in the air, its all wrapped around the crank pulley now...a real mess.
No idea how long this belt is..
Anyone know what size belt to ask for, width and length?
   / What size belts (MT372 with 50" Haban) #2
Once you have cleaned up the shredded belting, could you not run a (say 1/2") rope around the various pulleys and measure the rope for correct length?
I suggest 1/2" as that would simulate the inside seated belt length.
Also look carefully at the various belt pieces as you may still have the part number showing as all makers generally have their part number imprinted somewhere on the belt. (usually on the outside surface)
An automotive (or industriel belt supplier) will generally be able to cross referance and recognise any belt part number.
If in Canada I'd suggest GBS (General Bearing).
2016 FONTAINE 53FT SPREAD AXLE DROP DECK FLATBED TRAILER (A53426)
2016 FONTAINE 53FT...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
E-Z-Go Freedom TXT Electric Cart (A51694)
E-Z-Go Freedom TXT...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2018 JLG 10054 TELESCOPIC FORKLIFT (A51406)
2018 JLG 10054...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
