What Size Batwing
   / What Size Batwing #1
1990F-150
Sanger TX
2023 LS MT240HE. Kioti ZT. Honda Pioneer 520. Ford 8n. Ford 9n. Massey Ferguson 1080. Ford 2000
Hey guys, I'm in the market for a batwing mower and am not sure what size to get. I'm currently debating between getting a 12 ft or 15 ft mower. it will be ran behind an 82 PTO hp Massey, so I'm pretty sure it has the power to run either. The primary use of the mower will be for my property maintenance business, and it will be hauled on my 30' trailer consistently. If anybody has any input on what they were happy with I'd love to hear.
   / What Size Batwing #2
You might consider defining your task at hand in a bit more detail. A 2WD older MF of that horsepower and weight will certainly handle either a 12 or 15 foot mower, assuming the land is reasonably flat. And that you are not charging through heavy 4-5 foot high thick weeds or woody growth...that's a different environment entirely. Hilly, wet ground is another challenge of its own.
One point you might also consider is final weight of the tractor and mower. A tricked out, heavier batwing, replete with chains and blade guard "rings" will push 3 tons. Add to that a weighted tractor of perhaps 9-11K pounds and that is a serious load for most farm pick-ups and trailers. I don't know how your individual tractor might be ballasted, but you see where I'm going with that thought.
Not that all batwings weigh that much, but my Bushhog 2815 does, and there are even heavier ones in service for really tough environments. A lighter duty 15 foot mower will weigh less, but won't take as much abuse on its gearboxes and drivelines. And a 12 foot will also be lighter, but might be an item with fewer buyers when you want to trade. Most farmers lean toward 15 and 20 foot mowers since they normally have larger tractors to handle them. Speaking of which, a 3 ton piece of equipment can get into a serious argument with the tractor when you start downhill with it. All things to consider before you buy something.
So, to your original question, most brand name mowers will do a good job and you can get parts easily. For myself, my experience with the Bushhog brand has been good, so I buy them. Others, like Haydude, like the John Deere mowers. I have a farmer friend close by that swears by Land Pride batwings. One thing you should keep in mind, though, is that each brand has different weights of batwings of the same width in its catalog - make sure you are comparing apples to apples when looking at these. Salesmen might offer you a cheaper 15 foot in a particular line, and naturally there's a reason for that... Use gearbox size and total weight a starting point for comparison shopping.
I'm sure others will chime in with their thoughts and experiences as well.
Best of luck.
   / What Size Batwing #3
I have a 12 foot batwing that I pull behind my 4707 Massey that has 70 hp. In really thick stuff, it cuts great, but I wouldn't want to try to do that with a bigger batwing. On ground that I've cut before, I have way more power then I need for a 12 foot batwing and I feel that I could handle a 15 foot mower.
My neighbor has an 85 hp, 2wd tractor that he uses for his 15 foot batwing. He mows all the time, so it's just maintaining his fields and trails. He mows pretty fast, and the 2wd turns round a lot tighter then my 4wd. Watching how he can maneuver that tractor has me almost wanting a 2 wd tractor for mowing. It's night and day different.
For really thick areas, he uses a heavy duty 6 foot cutter. Then when that area is under control, he maintains it with the 15 foot batwing. He told me that he has plenty of power and he's offered to let me use his 15 foot batwing to see how it works for me, but I'm not going to remove my mower just to try his. It's too much work connecting it.
If your land is overgrown, you might have to cut it high, or go super slow the first time, but you should have enough power to pull a 15 foot batwing to maintain your land once it's under control. If it's already been mowed regularly, then you should be fine.
   / What Size Batwing #4
I recently bought a 12 batwing. For trailering, carefully check both the width and length of the mower, plus of course your tractor. Fitting on a 30’ trailer might be tight, and they are not particularly narrow when folded.
   / What Size Batwing #5
If you are going to be mowing the heavy, nasty stuff I get into, I’d go with a heavy duty 15’.
Get chain shielding and deck rings. Invaluable options.
   / What Size Batwing #6
What are deck rings?
I googled it and found several links that mention them and they are an option (Bush Hog site) but doesn't actually show what they are or what they do.
   / What Size Batwing #7
Not that all batwings weigh that much, but my Bushhog 2815 does, and there are even heavier ones in service for really tough environments. A lighter duty 15 foot mower will weigh less, but won't take as much abuse on its gearboxes and drivelines. Speaking of which, a 3 ton piece of equipment can get into a serious argument with the tractor when you start downhill with it. All things to consider before you buy something.
I have wondered if one could make a hydraulic cylinder actuated brake for a pull type bush hog to help keep it from pushing the tractor around.
I was thinking about a piece of steel pushed against the bush hog tire(s).
   / What Size Batwing #8
Its a large circular ring welded to the bottom of the deck above the blades. Keeps blades from chopping into deck.
   / What Size Batwing #9
Unless you are mowing some serious slopes a 3 ton mower on an 85 HP tractor should be no problem with mower pushing tractor around.
   / What Size Batwing
Thanks guys, it seems like the tractor should be able to run a 15’ batwing fine. I live in North Texas, so I don’t really have to worry about any serious slopes. The batwing won’t be used for any serious brush either, just overgrown pastures. Now I just need to make sure that the mower will fit on the trailer ok before I purchase anything just yet.
2013 AMSIG S/A Solar Towable Message Board (A46683)
2013 AMSIG S/A...
2013 Ford Explorer SUV (A48082)
2013 Ford Explorer...
Deutz F3L 912 2WD Utility Tractor (A49346)
Deutz F3L 912 2WD...
Diesel Pump , Hose and Handle (A46684)
Diesel Pump , Hose...
2017 Peterbilt 567 Tri-Axle Dump Truck (A46683)
2017 Peterbilt 567...
Kubota ZD1211 (A46684)
