What size attachments for TC30
   / What size attachments for TC30 #1
fctadam
Upstate NY
2004 TC30
Looking to purchase some attacments for my TC30 and backhoe. I'm interested in a rear blade, box blade, and york rake. I was wondering what sizes to purchase for my unit.
I was also wondering about what everyone thought about the brand King Cutter for the above toys, for my baby.
   / What size attachments for TC30 #2
When I bought mine the dealer recommended a 5' box blade, 6' back blade and rake. So far I've only used the back hoe and box blade on the TC 30 (work's killing me /forums/images/graemlins/tongue.gif). I have used the back blade and rake on a little Kubota B6100 (14 hp). Based on that you might try a 7' back blade and rake. You might even be able to use a bigger box blade but in my experience traction quickly becomes an issue.
Good luck
Rodger
   / What size attachments for TC30 #3
I have a King Kutter box blade and it works fine for everything I needed so far.
I had a light duty $200 King Kutter rear blade, I didn't like it at all. I later got a King Kutter (medium duty) "Professional series" rear blade and I like it much better. It cost a bit more (around $420) but it is a heavier/sturdier built blade. If you get the KK rear blade go with the Professional series..
   / What size attachments for TC30 #4
I have a TC33DA with a 72" Rear Blade and 60" Box Blade. They both work well and were the recommended size from my dealer. During heavy digging/gravel moving I need to keep it in FWD to maintain traction and still slip a little when the going is slick. Depending on your use a 66" (5 1/2') BB may be acceptable. Since my rear wheels are 60" wide, I would certainly go 66" if I was to do it again. I use the rear blade mostly for snow so an 84" would work for that but when grading a 72" is a good size.
...Derek
   / What size attachments for TC30 #5
I'd suggest a 6' rear blade, unless you're doing really light work, then you could go to 7'. Probably a 5' box blade. 6' brush hog/rotary cutter. 6' or 7'foot rake - the 7' should be no problem.
   / What size attachments for TC30 #6
Check out the Bush Hog 5 1/2 foot box blade and cover your tracks... you should have no problems with it... at least I don't.
Rich
   / What size attachments for TC30 #7
</font><font color="blue" class="small">( Looking to purchase some attacments for my TC30 and backhoe. I'm interested in a rear blade, box blade, and york rake. I was wondering what sizes to purchase for my unit.
I was also wondering about what everyone thought about the brand King Cutter for the above toys, for my baby. )</font>
I think a wide box blade is over rated and the speed with which you can pull it is under rated. I may be imagining this, but BB's seem to work more efficiently at a higher speed. I think a 5 footer will cover your tracks and you can pull it at a good clip. I wouldn't go any bigger unless you are very patient in lower gears, and don't use it too often.
Box blades catch a lot of abuse. If you plan to work it a lot, get one that's heavily built. Something on the order of 500-600# for a 5' BB will not likely come apart on you.
   / What size attachments for TC30 #8
i use a kk 6' box blade on my tc30 with no problem just did 60 ton of #2 stone with it and no problems, but need to keep in 4wd, used mid-range on the hydro. As far as the cutter the dealer strongly recommended a 5' hog. personally i'll probally get a 5 1/2' or 6' to cover the tires. i also use a 6' york rake with not even a hint of a problem. I used a 5' cutter with my 1320 (21 hp) and no problems with it. so i'm sure the 6' would be fine on the tc 30
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
40ft Shipping Container (A49461)
40ft Shipping...
