What should a 50 hr Service for a L3710 HST cost?
   / What should a 50 hr Service for a L3710 HST cost? #1
KC135plt
St Louis
Kubota L3710HST W.R. Long Grapple Bucket SQ72 Bush Hog 6' Box Blade Stihl 362 Stihl 290 Stihl 029 Stihl
I have a 2001 L3710 HST. What should it cost for me to have the 50 hr service done and have the Transmission/front axle case oil changed with Super UDT? The dealer I bought the tractor from quoted me a total price of $420. Seems a little high to me, this is also the same guy that said the Super UDT will cost me $13.40 a gallon if I bought it from him (even in the 5 gallon buchets). What do you guys think?
Bob in Wichita
   / What should a 50 hr Service for a L3710 HST cost? #2
I did the 50 hour service myself on my 3010HST and would not recommend doing yourself if you are not mechanically inclined and can not dispose of 12 gallons of oil correctly. I used 12 gallons of super udt, hydraulic filter, hst filter, and engine oil & filter. The original hst filter is a bear to get off. You will also need a big socket to take the strainer out to check for shavings-mine had none. The tractor is not quite high enough to put 5 gallon buckets under so tractor was raised. I had approximately $250 in 12 gallons of super udt oil, hst filter (about 65) , hydraulic filter, and motor oil and filter-plus the big socket I purchased as I did not want to use a crescent wrench. $420 sounds like a lot of money but it took me approximately 4 hours. Not hard work though. I will use Amsoil full synthetic oil for the hydraulics at the 400 hour service.
   / What should a 50 hr Service for a L3710 HST cost? #3
KC135plt
I had a little over $250. in fluid/filters plus a good half day doing the work and cleaning up. I don't think the $420. is extremely unreasonable for having it done.
regards
Mutt
p.s. if you decide to do it yourself, get some type of pan that will catch the fluid out of the front end/w3tcompact/icons/wink.gif.
   / What should a 50 hr Service for a L3710 HST cost? #4
Just got my L3410 back from it's 50 hour service last friday, here is the break down on cost. Pick up/ return $25.00,KUB7000-74035 oil filter 6.00,KUB15521-43160 fuel filter 3.55,KUBTA040-93230 outer air filter 15.60, 5 quarts 15W40 11.00, L99GS9 Util tract minor ser 82.95, EPA charges 1.50, KUBTA240-59900 HYD TRAN Filter 49.19, KUBT0070-37710 USE33960-82630 23.04, Super UDT 10 gal 161.40, Labor 107.95, tax 13.49.....Total $392.72 Seemed high, but no mess on the garage floor and it just didn't have the time to tackle it myself, plus they washed it too! Hope this helps. For some reason my user name won't take? joeinindy
   / What should a 50 hr Service for a L3710 HST cost? #5
Most of the dealers give the first 50 hours for free,but if you have anything extra done than one pays.
Far as pick up/return..thats a fair price.
I would rather have been there to see the service work done,for one can get some pointers.
Did they drain and replace the oil in your front axle also the radiator?
Sounds like your all set for a while./w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / What should a 50 hr Service for a L3710 HST cost? #6
My 50 hour was done on-site and cost $385. Course I didn't get any wash and wax with that/w3tcompact/icons/wink.gif The point on disposing of large quantities of waste are well made - it sure can get to be a hassle. BTW - I think the oil fill on the 3710 is a real pain in the butt ('specially if you don't have a long flexible funnel).
Andy in NH
   / What should a 50 hr Service for a L3710 HST cost? #8
I do my own service on my L3710, the 200 hr service cost less than $250, 10 Gallons of Super UDT, hydro and trans filters, oil filter, 10 quarts of 15/40, and ~1.5 gallons of 90 W gear oil for the front axle. I also changed the antifreeze and thge fuel filter since the machine is a little over 2 years old. Since this was the 2nd time I've done a complete fluid change it only took 2 hrs. The first time it was more than a half day affair. Re. fluid disposal - my dealer is more than willing to take back the used oil. I believe it's a New York state law, if they sell oil they must take it back for recycling.
   / What should a 50 hr Service for a L3710 HST cost? #9
Now if I'd only thought ahead.../w3tcompact/icons/crazy.gif That's exactly what
I wished for (after bending a plastic filler spout and having to pour real slow).
Andy in NH
   / What should a 50 hr Service for a L3710 HST cost? #10
Well if you do decide that's the one for you, the first thing you need to do is pull out the screen that it comes with (it,s got a little tab for removal and can be reinstalled if you like) It empties real slow with the screen and as long as the funnel is clean you should'nt be getting any junk out of a new jug of fluid.
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2017 Buick Encore (A50324)
2017 Buick Encore...
