Loader What RPM speed should I use?
   / What RPM speed should I use? #1
azop
Bronze Member
What RPM speed should I set the tractor at for driving around or using the FEL? I was around 1900 and then set it at 2300 when I was going up a hill in reverse. Is there a RPM range I should stick in, no matter the gear setting?
   / What RPM speed should I use? #2
I don't have a Bobcat but for loader use I run my tractor between 1800-2000 RPM for snow removal, dirt, gravel etc. I have high, mid, and low range and mostly use mid range and control speed with the HST pedal.
   / What RPM speed should I use? #3
There is a small red triangle on the gage that I believe marks the RPM that one should use for that kind of work, but I may be wrong, it may mark the max RPM that should be used.
   / What RPM speed should I use? #4
I don't have a Bobcat either but for driving around and and FEL work I run at 1700-1900 RPM. My HST has low, medium, and high range. I use low for heavy loader work. Medium for snow removal and moving loose soil and gravel with the FEL. I use high for road gear.
   / What RPM speed should I use? #5
The HST and loader hydraulics are alot more responsive when you run over 2000.
I've primarily run in the 22-2300 range for snow removal with my ct335. Sometimes it takes a little more with the heavy stuff. As you get to know your new tractor it'll tell you when it needs a little more or less throttle. It'll feel right and sound happy.
   / What RPM speed should I use? #6
I run mine at 2500rpm. The hydraulics and hydrostatic drive work really well there.
   / What RPM speed should I use? #7
Yes, you have to run an HST a little faster than you would a gear tractor in order to keep the pressure up on the tranny. I don't own one of these, but I'd think you'd want to be 2000 rpms or more. My JD HST owner's manual says to run at full throttle when in motion.
   / What RPM speed should I use? #9
I heard some of green tractors fluid will overheat if the motor is not revved up enough. Bobcats have a indepent cooling system for the hydraulic fluid. The more it is revved up the better it will run.
   / What RPM speed should I use? #10
The triangle on the RPM guage is for the PTO operation. The triangle RPM gets you the 540 RPM on the PTO. If you operate over that you can damage your PTO driven implement. Driving around w/o PTO engaged then you can run whatever RPM you want but the higher the better for the HST. I use over 2000 for sure and probably more like 2300-2500 when using the loader.
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
Bobcat 709 Skidloader Backhoe Attachment (A50774)
Bobcat 709...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
