What RPM should I use to mow
   / What RPM should I use to mow #1
garry
Bronze Member
Ohio
JD 1050
I have a 1997 Steiner 430 Max with a 20hp Onan. It has a 5 foot mower deck. This is my first year to mow with it. What RPM should I be running when I am mowing?
   / What RPM should I use to mow #2
I'm not familiar with that particular machine, but most small engines like to be run at WOT, or pretty darned close to it, for a power intense application like mowing.
I have the Operator's Manual but it does not address RPM operating speeds.
   / What RPM should I use to mow #4
Wide open throttle . That is where the engine makes peak power, peak cooling airflow , no lugging which wears parts and highest blade tip speed to cleanly cut the grass .
   / What RPM should I use to mow #5
I cant think of any small engine driven mower that isn't supposed to be ran at full throttle. You need that RPM to get the blade tip speed up high so it cuts cleanly and discharges cut material cleanly. You may also need the high RPM to get proper function of the drive motors on hydrostatic driven machines.
Tractor PTO driven mowers need to be ran at the rated engine speed that produces the correct PTO speed, usually 540 rpm for rear mounted mowers. This speed will be marked on the tachometer and may be wide open throttle or in some instances a few thousand RPM less than full throttle. This speed is usually marked at the speed the engine delivers peak HP. You may be able to throttle back a bit from this setting IF you have plenty of power for the mower AND you continue to get acceptable cutting results.
2016 GMC Savana (A50120)
2016 GMC Savana...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
More info coming soon! (A50322)
More info coming...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
