What Real Difference does the Oil's Ratings Make?
   / What Real Difference does the Oil's Ratings Make? #1
RWEST
Windber, PA
ALL J-D's: 955, X595, 6x4 Diesel Gator, CX Compact Gator, 310D Loader/Backhoe (4x4, turbo, extend-a-hoe)
So, yesterday evening I'm sitting in the garage waiting for the latest batch of wild thunderstorms to get finished (they've been spaced about perfectly - just as things dry out enough from the last ones to get some work done, along comes a new bunch :( ) and I get to looking at some oil jugs. One, Castrol Syntec 5w-50 is rated "CF". A jug of Rotella "T" 5w-40 has a CH-4 rating. So I start pondering - what advantage, if any, is there to using an oil with a '-4' rating in an earlier engine which only requires a CF, or CD, or one of the earlier rated oils? Do the '-4's' lubricate better? Handle soot and crud better? :confused:
   / What Real Difference does the Oil's Ratings Make? #2
The number 4 designates it is for a 4 stroke diesel engine, so don't use it in your old 2 stroke Detroit. As for the API letter ratings the higher the letter the better. The most recent upgrade in diesel engine oils was the CJ-4. The CJ-4 oil spec represents the most drastic improvement in diesel engine oil standards ever. Here's a link to the API's own chart that describes the different spec's.
http://www.api.org/certifications/engineoil/categories/upload/EngineOilGuide2006.pdf
   / What Real Difference does the Oil's Ratings Make? #4
KICK said:
does anybody have any of those anymore.
Some local digger has one in an old Louisville. Sounds like a 6-71 inine. A local farmer has a 6v71 in an excavator without mufflers !!!! When he cleared the field by my house you were up at 7:00 am on sunday morning !!!!
   / What Real Difference does the Oil's Ratings Make? #5
Got two setting at my house. :)
   / What Real Difference does the Oil's Ratings Make? #6
We run some old 4-71's in mobile generators and have some newer 6V92TA's in some big mobile Air conditioners. we run the dog piss out of them. the 4-71's just keep chuggin away with 12,000+ hours but the 6V92's we have are only about 10 years old and <3,000 hrs and they are wore out. not too happy with them.
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
