What PTO speed on 1510D for PTO generator?
   / What PTO speed on 1510D for PTO generator? #1
brotherjohn
central Florida and northwest Alabama
YM1510D
Also, what are the advanhtages/disadvantages of making a 3 point frame for the generator, compared to a trailer, or stationary mount? /forums/images/graemlins/confused.gif
   / What PTO speed on 1510D for PTO generator? #2
Your pto gen is likely set for an input speed of 540, meaning you need to run your tractor's pto at that speed. Your best hp:rpm ratio is going to be with your pto set on it's lowest of the 3 levels, if you have the 3spd pto. Yes.. you could set for a higher pto speed, and run engine at lower rpm.. but you would not be getting full use of your tractor hp.
If the electrical load was super low.. only a fraction o fthe pto gens output and your tractor hp range.. then that should be ok, and save bit of wear and tear and noise.. but otherwise.. just run 540.. etc..
Soundguy
   / What PTO speed on 1510D for PTO generator? #3
Advantages more manuvreable & portable.
Disadvantages-- Not as fast hook up.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53473)
2017 Yale GLC050VX...
2R S-TINE CULTIVATOR W/ ROLLING BASKETS (A51247)
2R S-TINE...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53473)
Kubota SVL65-2...
