Oil & Fuel what power steering fluid for 73 ford 3000
   / what power steering fluid for 73 ford 3000 #1
tractorman38
meansville ga
none right now
I would like to know if anyone can tell me what size belt and what power steering fluid goes in and on my tractor.? I just purchased it last week.
   / what power steering fluid for 73 ford 3000 #2
The manual says the power steering reservoir is filled with Ford Oil M2C-92-A or SAE 10W. This manual being 40+/- years old, I'm not sure how that translates to current oil. But it's a place to start, right? I usually call my local New Holland dealer and they translate for me.
Side note: You can pick up a decent manual on ebay for about eight bucks.
   / what power steering fluid for 73 ford 3000 #3
I'd replace it with a synthetic power steering fluid. Have done this on all my vehicles over time.
Ralph
   / what power steering fluid for 73 ford 3000 #4
New Holland 134 hydraulic oil, or an oil meeting the current 134 spec. Same oil you want to use in the transmission and rear axle/hydraulic reservoir. Motor oil, 134 and antifreeze are the three fluids you need for your 3000.
   / what power steering fluid for 73 ford 3000 #5
just what he said. ;)
Thanks guys I put ford automatic trans fluid in it but ill change.
   / what power steering fluid for 73 ford 3000 #7
unless the pump is shot. it will steer with atf fluid in it.
I know guys that have a leaky pump that run atf for $$ reasons. it certaintly won't kill it.
I prefer utf myself.
2019 LayMor SweepMaster 300 Towable Ride-On Rotating Broom Sweeper (A44571)
2019 LayMor...
Aqua Sculpt Reviews 2025: The Latest in Body Contouring
Aqua Sculpt...
264 Gallon IBC Tank With Drain Valve (A42745)
264 Gallon IBC...
INOP/NON RUNNING 2016 International CT660 Truck, VIN # 3HTJGTKT6GN292959 (A44391)
INOP/NON RUNNING...
SAND BLASTER AND SUPPLIES (A45333)
SAND BLASTER AND...
KENWORTH FUEL TANK (A45046)
KENWORTH FUEL TANK...
