What oil
   / What oil #1
csuengr
Loveland
Ford 1310
It has come time for another oil change. It's a 1984 Ford 1310. The tractor sees about 15 hours of use a year, as in it has a total of 544 hours on it. The oils gets changed every three to four years. I do, however, try to make sure the engine reaches operating temperature whenever I run it. There are so many oil choices and was wanting some recommendations on a oil that does well under these conditions. The tractor takes a whopping 3.5 quarts, so cost isn't that important. Thank you.
   / What oil
And I posted in the wrong section. Can someone move please. Thank you.
   / What oil #3
I love Sheaffers out of St Louis, oldest refinery in USA their Supreme 7000 or 9000 can't be beat I use 15/40 but mine is a diesel. Their website has a lot of information. I suppose you are in Loveland Colorado?
   / What oil #4
Based upon the extended time it goes between changes, I'd suggest a synthetic oil in the weight range the manual recommends. Pretty much any name brand synthetic diesel oil should be fine.
   / What oil #5
rotella T6 is a very good choice. It is synthetic and will hold up well on the long service intervals.
   / What oil
Yep, Loveland, CO. And the tractor is a diesel, all 1.0L of it.
STORAGE FEES (A51222)
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
1043 (A50459)
1043 (A50459)
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A51039)
2016 Kawasaki 70...
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
