What oil for 3000 select o speed?
   / What oil for 3000 select o speed? #1
Millsi
Bronze Member
Brisbane Australia
Iseki TX2160f, 196X Ford 3000 Select-O-Speed
Brains trust, I'm aware that the spec is MC134D and I'm happy to spend the extra $$ on New Holland brand oil (even though it's made by someone else).
The problem is we cant get New Holland oils here in Australia (that I can find).
I have found Penrite and Fuchs products that meet the MC134D specs, but I'm not sure that they would meet the exact viscosity etc of the New Holland oil.
My SOS works very well hot or cold, only small issue is having some creep in R1 and R2 when cold, so I don't want to risk making things worse.
It's a 1966 model if that makes any diference.
   / What oil for 3000 select o speed? #3
so you found oil that meets the listed specs. what are you waiting for. :)
Thanks Soundguy!
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
