What model did the 2320 replace?
   / What model did the 2320 replace? #1
Phil D
Hi All,
Test drove the 2320 today and am most impressed. Needing to continue to do my due diligence as the cost of the 2320, FEL and mmm may be too much.
What has the 2320 replaced? What model(s) might I be looking at in a similar 4wd, quick loader removal and similar hp as the 2320 but older and therefore a bit less expensive. I can sacrifice the slick body styling but am looking for a similar performance category particularly with the easy-off FEL.
Once again, thanks again for any replies. Best-Phil D
   / What model did the 2320 replace? #2
IIRC - it replaced the 4100/4110
   / What model did the 2320 replace? #5
Thanks guys. Any obvious reason I'd shy away from checking out the 4110 or 4115 vs the 2320?
Nice pole barn, Kenny D! And quicly done. May I ask your total cost for the project?
   / What model did the 2320 replace? #8
They are great machines...no reason not to include them in your search.
   / What model did the 2320 replace? #9
As kennyd said, they are great machines. I have had a 4100 for nine years, almost 1000 hours, NO problems. ONLY reason I am upgrading is to get a cab for cold winters and I do need a little more HP.
   / What model did the 2320 replace? #10
100% Correct. Great tractors also! Not that I am biased or anything...
NOT that I have noticed either Kenny !!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
