What lubricant for front axle?
   / What lubricant for front axle? #1
trook
North Central Mississippi
JD 5075E Cab
I own a 2009 JD 4320, and the front axle lubricant is low. It's not even on the stick. I can't seem to find what kind of oil to use in the operators manual. I have a gallon of transmission/hydraulic fluid that I bought from the dealer a few months ago. It says it meets John Deere standard JDM J20C.
Is this safe to use in the front axle or do I need something else? :confused:
To clarify, the oil I have is JD HY-GARD transmission and hydraulic oil. It says it is used to protect JD transmissions, final drives and hydraulic systems.
Well, I consider my front axle to be a "final drive". However, I thought it might make more sense to use gear oil rather than hy-gard.
Your thoughts?
   / What lubricant for front axle? #3
Your manual should specifiy somewhere what lube to use in the front differential. Check again where it tells about changing the front diff oil. I'd figure it would use the JD Hy-Gard but I'd check with a JD dealer to be sure if you still can't find it in the manual.
   / What lubricant for front axle? #4
My 2320 used GL-5 gear lube..
   / What lubricant for front axle? #5
Straight from the manual:
Transmission and Hydraulic Oil
IMPORTANT: Avoid damage! Use recommended oil only. Do not use engine oil or type F automatic transmission fluid.
Choose oil viscosity based on the expected air temperature range during the period between oil changes.
John Deere Low Viscosity HY-GARD transmission/hydraulic fluid is recommended. John Deere HY-GARD transmission/hydraulic fluid may also be used for temperatures above -18 deg C (0 deg F).
Other oils may be used if they meet John Deere standard JDM J20C or J20D.
As for me - I used the low-visc. Hy-Gard from Deere when I serviced a 4120.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
2022 Bobcat T770 Compact Track Loader Skid Steer (A49461)
2022 Bobcat T770...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
