What lube for off Road mini bike chain
   / What lube for off Road mini bike chain #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I went to Tractor Supply and bought a Coleman Mini Bike. Now it's time to lubricate the chain. The only thing I've found in the instructions say to use (chain lube) I'm considering chainsaw bar oil, chain wax, or 10W-30. Does anyone have a preference?
   / What lube for off Road mini bike chain #2
Go to a bike shop and buy a can of bike chain spray lube
   / What lube for off Road mini bike chain #3
I always used a spray can of chain lube. Got it at the motorcycle shop. It "dried" on the chain and looked like wax. Didn't attract & hold dirt/dust quite as bad a a "wet" lube.
   / What lube for off Road mini bike chain #4
Both of the previous replies are correct. A chain will spit all regular oil off as it spins around the sprockets. Real chain lube gets somewhat tacky once it is on the chain so it tends to stay put.
   / What lube for off Road mini bike chain #5
Chainsaw oil would work just fine
Been riding dirt bikes since I was in grade school and if you had a high powered motocross bike I would recommend chain lube made specifically for that application. You arent spinning that mini bike chain all that fast. Just make sure you keep it lubed
   / What lube for off Road mini bike chain #6
Any of those will work. If I had a bike, I'd use my spray Fluid Film. Bar oil is probably 10w30 but labeled 30w. That's probably 10w30.
Think even graphite would work and be less messy.
Ralph
Thanks to everyone. Now, I've got a little thinking to do.
Stuck
   / What lube for off Road mini bike chain #8
   / What lube for off Road mini bike chain #9
I bought two of those Coleman’s. They are a hoot to ride. I modified one with a Torque converter. I ground off the throttle limit screw on both. Very good value for the price! If you will be riding daily I would get the motorcycle spray film lube. If ur only riding on the weekend I would use chainsaw bar oil (this is what I use ).
   / What lube for off Road mini bike chain #10
O ring chain or not? Alot of Oring chains look like they need to be lubed yet prob dont.
1979 Trail 40 ft Hopper Bottom Grain Trailer - Dual Grain Doors and Leaf Spring Suspension (A44789)
1979 Trail 40 ft...
2007 CAT 308C Excavator (A42203)
2007 CAT 308C...
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2011 DRAGON PRODUCTS 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2011 DRAGON...
LIGHT TOWER (A45046)
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
