What kind of Universal Tractor Earl?
   / What kind of Universal Tractor Earl? #1
KICK
Platinum Member
stilinlimbo, FLA
Mitsu 2000, Hew Holland 875, JD 125
what kind of hydraulic and gear earl do you think a Mitsubishi D2000 would use
taint gotta book on the thing, it has a common tranny and hydraulic system.
one thing for sure, if nobody know what Mitcheepussee specs, I'm gonna dump something in there and see what happens.
   / What kind of Universal Tractor Earl? #2
I suspect a standard UTF fluid would work. I can't say I have ever run across a Mitsubishi fluid spec before so I'm not sure if they have one of their own or use some other manufacturers spec.
Thanx DP.
about what I figured.
I'll use and maintain this tractor as long as I can but I doubt I'll ever be able to get parts for it if she breaks.
so UTF it is.
   / What kind of Universal Tractor Earl? #4
Mitsubishi still makes industrial equipment. I'm not sure if they might be able to get parts for you or not. Might be worth a try when the time comes.
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
Utility Trailer (A52377)
Utility Trailer...
Informational Lot - Financing (A55302)
Informational Lot...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
