What kind of trailer?
   / What kind of trailer? #1
EasyE
North Carolina
JD 2305
This is the trailer the dealer delivered my tractor on. What type of trailer do you haul your tractor with? I am using my mowing trailer at the moment but, when mowing season comes I don't want to have to unload all my mowers each time I need to use the tractor. I was thinking of buying a trailer like the one in the picture. Please enclose a picture if you can of your trailer to give me some ideas. Thanks.
   / What kind of trailer? #2
This trailer (in pic) has dual axle and looks to be "Heavy Duty" and this is what you want. Now depending on what you have for a tow vehicle? Can you pull this? AND HAVE BRAKING TO CONTROL IT. Too many people try to skimp on the trailer, well with ???? $$$,s in a tractor and equip. dont' cheat on the trailer. If you lose the trailer, you lose your tractor and accessories.
jw5875
   / What kind of trailer? #3
Heres a pic of my 14 ft big tex car hauler3500 lb axles[make sure the dealer includes the higher rated tires or you can only haul 6000lbs]tires.breakaway,brakes on both axles,ramps stored underneath.I got a little tractor,and cherokee to pull it.Id get a 16 or 18 ft for your tractor Im hauling loads up to 5000 with mine hauls/brakes nice.
ALAN
   / What kind of trailer? #4
I've been giving this a lot of thought lately. I'd love to have this trailer to move my 4010 with. I have a Ford Explorer and use my Dad's 18' car hauler right now. It is 77" or so wide and sticks out way past the sides of the Explorer. It is too much trailer for my little tractor, but it is free. /forums/images/graemlins/grin.gif I'd like to have the 14' 45LA due to its 60" deck. My FEL bucket is 53", and when I get a shredder/finish mower it will not be bigger than 5', so the width should be fine.
I concur with the other posters about the tow vehicle. My Explorer has a tow rating of 3500 lbs, but I only pull the tractor about 4 miles along a low traffic county road. If I was going to be on the interstate I'd use my Dad's F150. It is a much better tow vehicle.
   / What kind of trailer? #5
I agree with jw5875, don't skimp on the trailer. Think of any other future uses you may have for a trailer. Hauling dirt, a vehicle, 4 wheelers, snowmobiles etc. Pics of mine are in members photos / other / mahindra. I bought a 20' tilt bed to haul my tractor w/ implements, 4 wheelers, my buddies pickup that recently broke down etc. This spring I'll build sides for it that will fit in the side pockets to haul some topsoil and stone for the driveway. Trailers can have many uses.
Just my 2 cents.
George
   / What kind of trailer? #6
How about my fantasy trailer. am Superline Heavy Duty Low Profile 5 ton Black Dump Trailer. 6' x 12' TA, 11,960# G.V.W., 3,480# Empty, Remote Control, (4) Wheel Electric Brakes, Split Barn Door Tailgate, Slide Out Ladder Ramps, Radial Tires 225/75R15 D, (2) Telescopic Cylinder, 27" Deck Height, 20 1/2" Inside Bed Height,4.6 Cu. Yds. Capacity, Slipper Springs, (11) 2" x 4" Stake Pockets, Adjustable 2 5/16" Coupler, Rubber Mounted Lights, Bolt On 7k Drop-Leg Jack. I need a lot of gravel and topsoil at my place, and with this I could haul both. My neighbor just bought one last summer. It cost more than I paid for my tractor, so it's just a fantasy! /forums/images/graemlins/crazy.gif
</font><font color="blue" class="small">( This trailer (in pic) has dual axle and looks to be "Heavy Duty" and this is what you want. Now depending on what you have for a tow vehicle? Can you pull this? AND HAVE BRAKING TO CONTROL IT. Too many people try to skimp on the trailer, well with ???? $$$,s in a tractor and equip. dont' cheat on the trailer. If you lose the trailer, you lose your tractor and accessories.
jw5875 )</font>
I have a 2500 HD Chevy Duramax Diesel crewcab to pull with, I think it will do the job just fine. I have several heavy duty trailers all of which are dual axles and have brakes. I just don't have one long enough to carry the tractor with attatchments, that's why I was asking.
</font><font color="blue" class="small">( How about my fantasy trailer. am Superline Heavy Duty Low Profile 5 ton Black Dump Trailer. 6' x 12' TA, 11,960# G.V.W., 3,480# Empty, Remote Control, (4) Wheel Electric Brakes, Split Barn Door Tailgate, Slide Out Ladder Ramps, Radial Tires 225/75R15 D, (2) Telescopic Cylinder, 27" Deck Height, 20 1/2" Inside Bed Height,4.6 Cu. Yds. Capacity, Slipper Springs, (11) 2" x 4" Stake Pockets, Adjustable 2 5/16" Coupler, Rubber Mounted Lights, Bolt On 7k Drop-Leg Jack. I need a lot of gravel and topsoil at my place, and with this I could haul both. My neighbor just bought one last summer. It cost more than I paid for my tractor, so it's just a fantasy! /forums/images/graemlins/crazy.gif )</font>
Iowachild, I have a similar trailer I use in my business and you are right it will haul about anything you can put in it.
   / What kind of trailer? #9
I have a 20 ft Anderson equipment trailer. It is perfect for my needs. I have a New Holland TC-35D with 16LA FEL. It doesn't matter if I have the backhoe attached, or the bush hog everything fits on the trailer. It also leaves room to move the tractor backwards or forwards to adjust the tounge weight.
http://www.trailersforless.com/and_dump_EQ7185T_trailers.html
I went with the 20 ft lenght, and the options for the 7,000 lb axles. Also brakes on both axles and load range "E" tires.
I tow with a F-250 4x4 with no problems.
On edit: I have no fiancial connection with "Trailers for Less" I have bought 4 trailers from them and they have excellent service.
   / What kind of trailer? #10
I have had several trailers but my tilt bed is my hands down favorite. It cost a few more bucks but is safer than ramps and quick to load. I got a 20' 10,000GVW from H&H.
See picture.
2016 Bobcat E32i Mini Excavator (A50322)
2016 Bobcat E32i...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52748)
Adams FL24...
