What kind of teeth for rock rake?
   / What kind of teeth for rock rake? #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Hey All,
I am looking at a rock rake or landscape rake from Vevor. Here is the link: VEVOR Tow Behind Landscape Rake, 60" Tow Dethatcher with 21 Steel Coil Tines, Lawn Dethatcher Rake Attaches to 48" or 60" Toolbars and 3-point Suspension Systems, for Leaves, Pine Needles, and Grass | VEVOR US
I tried to select the 72 inch width but I could only select the 60 inch model. I thought about the spring teeth but couldn't add that option either. Anyway, what I am wanting to do is rake up rocks after I till a large area. I have lots of rocks. Really. From about 1/2 fist sized to about 1/2 football sized. I'm thinking the steel teeth would be best. My Yanmar tiller is 60 inches wide so I guess the 60 inch wide rake would be OK.
I need to plant a lawn of some sort over our drain field. Since it will need to be mowed just to keep the blackberries from taking over I need to remove the rocks. I have done this before with our other drain field. But that was about 25 years ago and I didn't have a tractor so I did all the rock removal by hand after I tilled the drain field with our old Merry Tiller. I'm too old for all that manual work now.
I realize the rake I am looking at will require some sort of way to attach to the 3 point. The rake is 180 bucks shipped. With the 3 point attachment the price goes to 470. I'm retired, own a machine shop complete with several welding machines, and can fabricate the 3 point mount. Maybe I can even figure out a way to use my box blade as the attachment.
My big question is should I use the steel teeth? Would spring teeth be better for removing the rock sizes I have? Also, should I try to order the 72 inch width even though my tiller is 60 inches wide?
Thanks,
Eric
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2013 Honda CR-Z Hatchback (A50324)
2013 Honda CR-Z...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
Quick Attach Pallet Forks (A47384)
Quick Attach...
