what kind of mower do I need?
   / what kind of mower do I need? #1
Jamucat
Halfmoon Bay BC
L-1501 Kabota Bobcat 763
I have a l1501 Kubota with FEL and Kelly Backhoe. I want to maintain about 3 acres of land that was cleared of the alders a few years ago and rough graded. I planted a pasture mix to keep the trees from coming back and that has worked somewhat. I want to mow it a few times a year to really discourage the trees.
What kind of mower do I want. I will have to find one used.
   / what kind of mower do I need? #2
This thread is old, did you find a mower? I have the same tractor L185DT 4wd. I use a 48 inch cutting width rough cut rotary mower (brush Hog type) which works well for rough terrain and small brush and wild grass. A finish mower would not do as well for tall grass and such.
Hi Thanks for the info. I am curious about your tractor. you say it is the same as my l1501 but the number you quote is different. Mine is a Japanese import aftermarket.
Still looking for a mower (cheap).
Thanks again for your input
Charles
   / what kind of mower do I need? #4
Location?
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2015 MACK GU713 (A50854)
2015 MACK GU713...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
