What kind of Hydraulic fluid should you use in a 2007 NH B95-699800781?
   / What kind of Hydraulic fluid should you use in a 2007 NH B95-699800781? #1
Maly' Ranc'
New Holland B95-699800781
What kind of Hydraulic fluid should you use in a 2007 NH B95-699800781? Can you use ISO 46?
   / What kind of Hydraulic fluid should you use in a 2007 NH B95-699800781? #2
What ever the dealer says. Useing the wrong hydraulic fluid on a system with wet clutches or brakes can get real expensive real quick.
   / What kind of Hydraulic fluid should you use in a 2007 NH B95-699800781? #3
I wouldn’t recommend 46 for the power train as it is missing the additives necessary for the friction components. The backhoe loader is a separate system and would be fine, but you might as well get the right oil for the power train to avoid any mistakes
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
2018 JOHN DEERE 310SL HL BACKHOE (A51406)
2018 JOHN DEERE...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2024 John Deere 333G Hi Flow Compact Track Loader Skid Steer (A50322)
2024 John Deere...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
