What kind of fluid?
   / What kind of fluid? #1
BodegaErik
Sebastopol, Ca.
Mitsubishi MT210D
I am curious what type of fluid I should be using in the front axel/differential of my Mitsubishi MT210D 4x4 tractor? Any help is appreciated.
   / What kind of fluid? #2
I don't know Mitsubishi, but the trans/hyd. fluid you currently use will do fine, but I would recommend 80w90 as it tends not to weep in warmer weather.
   / What kind of fluid? #3
Don't know what Mitsubishi recommends either, but Daedong built (Kioti, Bobcat, & now McCormick) come with trans/hyd fluid in the front for break-in, flushing purposes then recommend 80-90W after 50 hrs. I would imagine these front axles are all pretty much the same unless it is Limited Slip or lockable.
   / What kind of fluid? #4
I know in older yanmars it 90Wt. I cant imagine Mitsu being any different.
22ft T/A Gooseneck Flatbed Equipment Trailer (A52377)
22ft T/A Gooseneck...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2019 KENWORTH T880 DAY CAB ROAD TRACTOR (A51406)
2019 KENWORTH T880...
