What is two way Detent? Log Splitter
   / What is two way Detent? Log Splitter #1
LanceH
West Central Ohio
I am building a log splitter and was looking at a "Prince Two-Way Detent Valve, Model# LS-3010-2" from Northern Tool northerntool.com What is the 2 way detent? Does this mean that the lever will hold the pressure until the cylinder extends fully, then i kick the lever back and it auto retracts? If this is the case, is this practical to be used on a log splitter? Or should i just save $20 and go with a one way detent?
Thanks in advance for all your help.
-Lance
   / What is two way Detent? Log Splitter #2
Not sure about that:confused:
   / What is two way Detent? Log Splitter #3
I think you should save your $20
elad
   / What is two way Detent? Log Splitter #4
It would work just like you described, but a two way detent is considered dangerous on a log splitter and is not recommended. What it would do is allow you to extend the cylinder without having to hold the valve handle. This would create temptation to use that hand for other things (like holding the log in a certain position, etc.) or move around and do something else while the ram is splitting. From an efficiency standpoint I can see the attraction, but for safety's sake I would forgo that and get the single detent...
   / What is two way Detent? Log Splitter #5
I agree. Not a good option. The lever should center automatically when you let go, stopping the ram. the spilt secondneeded to consciously center it against the detent force is too much in many situations.
larry
Yeah, the more i think about it, the more I realize that safety is first-even at the sake of productivity. Also, if i do run into stubborn logs, i can release pressure easier with a single detent, where as with a two way detent i could blow a seal in the cylinder. Thanks guys. I'll go with the single.
   / What is two way Detent? Log Splitter #7
It's not an assembly line......Safety first.
Don
   / What is two way Detent? Log Splitter #8
I agree with the previous posts. 2-way detent is a bad idea for a log splitter. A detent on the return stroke is nice, though.
   / What is two way Detent? Log Splitter #9
Some woodsplitters come with an autocycle valve, which is what I added to my home made one. With the 2 way detent, you still have to hit the return. With the autocycle, your hands are away from the splitter getting the next piece.
   / What is two way Detent? Log Splitter #10
You're making the right decision. The two way detents are still both relief valve protected, though.
I've used those. They're nice, but the downside is that 80% of what I split is done well before the end of the stroke. I can see the advantage on a fast splitter or 2-stage pump. I'm not sure I would save any time running full cycles...what happens when it hits a tough spot? Does it autoreturn from that point?
2004 Ford Explorer 4x4 SUV (A42744)
2004 Ford Explorer...
2014 Ford F-450 Liftmoore 5000W Mechanics Crane Truck (A44571)
2014 Ford F-450...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
Sears Walk Behind Tiller (A44501)
Sears Walk Behind...
2011 Ford F-250 Pickup Truck (A44572)
2011 Ford F-250...
2014 DODGE RAM 2500 (A45046)
2014 DODGE RAM...
