Ballast What is too much ballast?
   / What is too much ballast? #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
Want to add a ballast to the M7040 for when doing loader work with full bucket (72 inch). Seems like the stability without is Ok at least it did not feel unstable when I did a couple of hours of digging with it. However I think the traction with 2000 pounds of ballast would be much improved allowing bigger bites when going into hard packed dirt. Thinking that I would buy a carry all and make myself a concrete block to fit on it. Does this sound resonable?
   / What is too much ballast? #2
You need a ballast if you are gonna be using the loader... that said, there are lots of posts that talk about "how much is enough" on these boards in general. Personally, I see ballasting for FEL work as much a safety thing as to increase traction and get bigger bites.
Actually, JD has a nice little printed brochure about the subject - something to take for free from the dealer when you are wearing your Kubota hat!
As for building your own - just make sure your design has plenty of room under it when lifted or you will find small slopes to be like "The Great Wall of China" as far as ease of traversing.
My rule of thumb is pretty simple - I'd get close to your lift capacity for the 3PT - and then you can safely say - you didn't under ballast the loader.
   / What is too much ballast? #3
Realize a couple things. The FEL has far lower capacity on most tractors than the 3pt hitch and also carries the weight well forward so while it can carry less, it has the advantage of leverage. Also realize that most "carry alls" have a capacity that is fairly low. You would be well off to make a good heavy weight for the 3pt, but a typical budget "carry all" may not hold as much weight as you may want/need. Figure out the capacity of your 3pt hitch and build a weight that is at least as heavy as your loader manual recommends, and if you have more capacity then adding extra weight won't hurt if it can be removed when you don't need it.
   / What is too much ballast? #4
My carryall is actually a 3ph hay fork with a platform built on top of it. The platform is removable when Ineed to use the hay fork for moving hay. I pile ballast and tool boxes on the platform when using FEL.
Thank you for all the replies. Very good advice. I like the idea of a three point hay carrier and modify to carry ballast. Thanks
   / What is too much ballast? #6
The 3ph hay fork should be capable of lifting 1500 to 1800 lbs, the weight of a heavy bale. So, you should be able to use at least that much ballast on it. That should be enough. I put about 1200 lbs ballast on mine when lifting 2800 lb FEL loads....and I need that much!!
20711 (A50323)
20711 (A50323)
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
Gleaner R50 Combine (A50514)
Gleaner R50...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
UNUSED TOPCAT QUICK ATTACH STUMP GRINDER (A51244)
UNUSED TOPCAT...
