What is this wire?
   / What is this wire? #1
07wingnut
Clearwater, BC, CA
BX23
Two questions actually. This is for a BX23. There is a wiring harness overtop of the motor and coming out of it is a double white wire terminating in a single terminal connector. Any ideas what it does, it isn't hot with the key on or off.
Secondly, when checking the oil level in the front axle, is the level with the dip stick screwed in, or just with the dipstick measuring without actually screwing it in?
Any replies are appreciated, I am new to this machine and there is a lot to learn.
   / What is this wire? #2
The wires are probably for an application you don't have. As for the front axle a 1/4" shouldn't make any difference.
   / What is this wire? #3
Billrog - - +
   / What is this wire? #4
I measure my axle fluid with the dipstick screwed in. Rather have a little more than not enough fluid.
   / What is this wire? #5
Looked at my BX2230 and the only double wire with connector is the one going to the engine stop solenoid. Does it stop ok? Is your engine a D902 or D905? have a single white wire going to temp sensor.
David
1042 (A50459)
1042 (A50459)
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2001 HEIL PNEUMATIC CEMENT TRAILER (A51222)
2001 HEIL...
TMA (A49461)
TMA (A49461)
