What is this thing called?
   / What is this thing called? #1
sandman2234
Super Member
Jacksonville, Florida
JD2555 and a few Allis Chalmers and now one Kubota
This came with some Toro Workman junk we purchased. Pretty sure it was pulled but a Toro Workman with a light duty 3 point hitch. Probably for smoothing sand traps or such?
David from jax
another view
can't make out the name...
David from jax
Not really obvious but there are small spring loaded pins in the last drag section. The front part appears to smooth the sand and then the springs pull the trash or twigs out?
David from jax
more name confusion...
David from jax
   / What is this thing called? #6
I think it is one of these:
For grooming baseball fields sand traps, etc.
Runner, I do believe you found it! Thanks!
Not sure what I will do with it, as my Toro Workman typically just do hauling and riding me around the neighborhood. I don't have any baseball fields or sandtraps to smooth (nor do I want any!!!) The smoothest I ever get things is with my 3pt landplane!
Maybe something to consider putting up for sale, but I seldom have time to deal with tire kickers, so it will probably get stashed out back somewhere!
Thanks, David from jax
1996 Ingersoll-Rand VR642C (A47477)
1996...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
