What is this code?
   / What is this code? #1
narampa
Bronze Member
canada
445 johndeere
My 445 John Deere is givin off this code _.. Or ONE long and Two short dashes.
I use to have the codes but have misplaced them. Any help would be appreciated.
I found out what it is. It is the air temp sender. I have the shop manual but it is not user friendly when it comes to finding the codes. If anybody has code for a 445 they can't figure out. Let me know.
   / What is this code? #3
Where did you find the codes? Can you give the section, assuming you are speaking of the tech manual. I browsed a bit, but didn't find the codes.
Glad you did.
Glad you did.
I have the 425 445 and 455 Lawn and Garden Technical Manual
The Codes are in Section 5 page 254
Component Locations are Section 5 page 125
   / What is this code? #5
narampa
Thanks for that info. Found it, but it was pretty discreet and could have been pointed out in the index to make it easier to spot.
:thumbsup:
Glad to Help
   / What is this code? #7
Hope I don't need it, but my son has my 445 now and just in case, I should know where it is. Put a sticky note on the CD for the page # and section 5.
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
3in Poly Pipe (A49461)
John Deere A Tractor (A50514)
John Deere A...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
