What is the weight of my L3240HSTC TLB
   / What is the weight of my L3240HSTC TLB #1
lockman4288
Wiscasset,ME
3240 HST TLB cab
Looking into purchasing a trailer I need to know the weight of my tractor an attachments. And recommendations for a trailer
Kubota L3240 HSTC CAB MODEL __?___lbs
LA724 w/ 60" bucket __?___lbs
BH92 backhoe w/ 18" bucket __?___lbs
   / What is the weight of my L3240HSTC TLB #2
To get an accurate weight you need to put it on a scale. I am lucky that I have a scale on the highway 3/4 mile from here.
Have an L3130 with a LA723 loader with quick attach adapter remote hydraulics on loader and grapple bucket. On the back a Bradco 408W backhoe with subframe and thumb. I also 2 have rear remotes and Top and Tilt cylinders mounted also. To move this I am using a Load Trail 20 foot tilt bed trailer it has 4ft stationary and 16ft tilting with 14k GVW and an all steel deck.
Weighed this last summer after going to friends to dig a trench and the tractor and grapple bucket plus extra dirt bucket were over 7,200 and trailer was over 4,200.
I do not think a 10K trailer would be ok for my tractor and glad I went with the bigger trailer so I have a little room. To get closer on your actual weight you will have to get tractor on scale as I think the Bradco is a heavier backhoe but is hard to tell but with you having a cab I think it will push you up to needing the 14k trailer for sure.
Trailer like I have
Tilt Deck Gravity 14,000 Lb w/6" Channel Frame Load Trail Trailer Manufacturing
David Kb7uns
   / What is the weight of my L3240HSTC TLB #3
The tractor and cab 3748
The B92 backhoe 1800
Loader 1168
Standard loader bucket 322
7038
   / What is the weight of my L3240HSTC TLB #4
David/Waxman - do your numbers include loaded rear tires? Just curious.
   / What is the weight of my L3240HSTC TLB #5
The weight from the truck scale was with the tractor loaded on trailer and yes the tires have Rimguard. I am thinking that I may be a little light on the weight as it is hard to tell how much weight is being transferred to the truck from the trailer.
David Kb7uns
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2006 CATERPILLAR D604S GENERATOR (A50854)
2006 CATERPILLAR...
19009 (A48082)
19009 (A48082)
