What is the Secret Handshake?
/ What is the Secret Handshake? #1
rpeter
Cumberland county Pennsylvania
Kubota B7800
MY new <font color="orange"> B 7800 </font> was delivered today, my first tractor. NO, I do not have pictures yet. After paying cash for the tractor I did not have enough money for a good digital camera /forums/images/graemlins/grin.gif
This is a real newbie trick, I have a woods BB60 Rotary Cutter that I took off to hall a trailer and can not get it back on again. I attach the lift arms, no problem. The top link attaches to the cutters clevis, no problem. What I can not get connected is the cutters driveline to the tractors PTO shaft. I spin the shaft so that it lines up with the cutters driveline slide it on and it goes about ½ way. I can not get it to slide all the way so that it will click.
So here’s my question, what am I missing, what is the secret handshake between these two /forums/images/graemlins/confused.gif
/ What is the Secret Handshake? #2
rpeter-
Are you pushing on the little spring loaded button? Hold it in while you slide the well-greased PTO parts together. Sometimes you have to push hard!!! Hope this helps.
Regards, Mike
The whole collar is spring loaded and I am pulling back on it. Did not notice a spring loaded button on the collar. Did I miss something /forums/images/graemlins/confused.gif
/ What is the Secret Handshake? #4
</font><font color="blue" class="small">( The whole collar is spring loaded and I am pulling back on it. Did not notice a spring loaded button on the collar. Did I miss something /forums/images/graemlins/confused.gif )</font>
I don't think you missed anything. Usually these connectors have a button or a collar, but not both. Yours apparently has a collar.
I wonder if you can pull the collar too hard, like past neutral, if you will? Maybe if you try letting up a little as the collar slides over the notch? Just a thought. /forums/images/graemlins/smile.gif
/ What is the Secret Handshake? #5
I had the same problem. search my post in the attachment section. 'can't get pto shaft on tractor" one guy posted a picture that made it real clear and other posters discussed all the other types of locks. Good Luck.
/ What is the Secret Handshake? #6
This would be the thread WW posts about:
Link
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
/ What is the Secret Handshake? #7
Here is the link to that thread: Can't get PTO shaft on tractor
... and here's the photo
Thanks guys, that was a real good thread. Sometimes I get so frustrated I can not think straight. I should have done a search first /forums/images/graemlins/shocked.gif
I did pull back, but did not think of twisting. I sure was shouting, looks like it should have been twist and shout /forums/images/graemlins/grin.gif
/ What is the Secret Handshake? #9
I have the pull and slide collar on some of my implements and you handle it just as described. On some of the implements that came with the new M5700 at the farm there is a different kind of collar. It's not the straight pull, slide and release type. This type of collar has to be rotated before sliding on to the PTO shaft and then released to lock. It took me a little while to figure that one out. You may have one of this type. Check it out.
/ What is the Secret Handshake? #10
Congrats on the paid off tractor. I still fight with my PTO shaft on a regular basis. I just cannot get the right positioning and twisting motion down.
I guess if I did it everyday, it would help. But every few months it turns out to be a new learning experience with a steep curve.... /forums/images/graemlins/blush.gif
-Mike Z. /forums/images/graemlins/grin.gif
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2014 KEYSTONE COUGAR CAMPER (A63569)
2014 KEYSTONE...
Skid Steer Leveling Plane (A64047)
Skid Steer...
429835 (A61166)
429835 (A61166)
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
