What is the HP of a Kubota B7100
   / What is the HP of a Kubota B7100 #1
arcteryx
Bronze Member
Texas
JD 3032E w/ Loader
Hi,
I am seeing numerous B7100 (some HST) that say the HP is 20. But according to tractordata, it's 16. Is there a 20HP b7100 out there? Or are these sellers just misinformed?
   / What is the HP of a Kubota B7100 #2
Misinformed, 'cause you know they wouldn't lie.
Thanks. A side question to this- could this mower handle a 4 foot mower? I read that every foot of mower should have 4 HP at the PTO. This would mean that 16HP at the PTO would be needed to run a 4 foot cutter. Or am I wrong on this?
I like these tractors, but need to run a 4 foot mower, so I was looking for a PTO with 16HP. TIA.
   / What is the HP of a Kubota B7100 #5
It's a little week for a 4 foot mower if your grass gets overgrown at all. Try to find the next size up Kubota, they had 18hp, or maybe 20hp
   / What is the HP of a Kubota B7100 #6
I have been mowing 3.5 acres of grass and assorted weeds with my 1982 B7100HST with a 60" MMM since I got it new. It is not a combination that you can zip through high grass at top speed, but it definitely gets the job done. Just got back from a 2.5 week trip and mowed the 8" plus grass in two cuts a day apart. First was with mower at highest setting, second was normal cut. I use standard after market blades that I regrind a couple of times a season to keep them sort of sharp.
Running a 48" mower should be no problem at all.
   / What is the HP of a Kubota B7100 #7
The B7100 is a nice little tractor. I would try it and if it doesn't work out then upgrade. I doubt you would loose much, if anything.
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A45046)
2013 FREIGHTLINER...
More info coming soon! (A44572)
More info coming...
325 Gal Tank (A44502)
PICK UP INSTRUCTIONS (A42021)
PICK UP...
CAT IT28 Wheel Loader Bucket (A44391)
CAT IT28 Wheel...
Club Car Electric Golf Cart (A44502)
Club Car Electric...
