What is orange light on dash?
   / What is orange light on dash? #1
dougfollett
Olympia, Washington.
Yanmar 1500
I have a Yanmar 1500 which has a simple dash. RPM meter on the right. On the left is a red oil pressure light with an orange light adjacent to it. I am assuming that the orange light is for overheating. I'm not positive though because it was on for a while the other day and the tractor didn't seem hot. It's got to be for overheating right?
   / What is orange light on dash? #2
The orange light is electrical. It means your battery is low. Aftere you run it for a while it should go off after the generator charges. This is a common event with the 1500. It is not over heat.
Hope this helps.
Whew! Thanks, I was beginning to get worried. Is there an indicator for overheating?
   / What is orange light on dash? #4
Yep, when a column of steam billows out from the front of the tractor, or blows a hose off, etc.
That is a good indicator of overheating! /w3tcompact/icons/smile.gif
Sorry.. just had to say it...
Soundguy
   / What is orange light on dash? #5
Well, Soundguy i'm glad you have cleared that up for us, I just thought it was time to steam the wrinkles out of my slacks or deep clean the poors in my face /w3tcompact/icons/smile.gif hehehehehe
   / What is orange light on dash? #7
Or as in my case a blown headgasket.
   / What is orange light on dash? #9
Doug,The orange light on your ym1500 is overheating warning.The sending unit is located on top left side of engine between air intake and fan hub mounted alternator.It has a yellow wire that plugs onto it.If light comes on and engine isn't hot,prolly need to replace sending unit.Also need to check wire for any raw spots that could contact metal parts as this will cause light to come on.If you don't have access to a shop manual,I'll be glad to send you a copy of the wiring diagram.
Looks like I'm going to have to actually get in there in look. Everyone else is saying it is the charging indicatior. I'm more apt to belive you since you have the diagram. I should be able to trace it back without the schematic. Thanks.
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
WORKSAVER RMB-325-PW LOT NUMBER 117 (A53084)
WORKSAVER...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
