what is non-detergent oil
   / what is non-detergent oil #1
Roto
Mid Maine
TC55DA and TC33D
In my post (hydrostatic drive worn out) a few people mentioned non-detergent oil instead of regular sae30 weight oil in my hydostatic transmission. I was just wondering what the difference is between non-detergent and regular sae30 oil.
Mike
   / what is non-detergent oil #2
Using non detergent oil for a time will tend to build up solids in the system that spaces that are worn and by changing to detergent and cleaning up things it creates clearances that are undesireable. I won't swear on the bible on this, but that is what I have heard from oldtimers.
   / what is non-detergent oil #3
Non-detergent oils where delevloped around 1940 before adds where discovered/made. They are now considered 'obsolete' and should only be considered for use in 'non-combustion' type applications such as a small hobby reciprocating air compressor for example. They are SA and SB symbol I think.
The main difference is price and what you get. If you like an oil that never cleans, buy it.
   / what is non-detergent oil #4
</font><font color="blue" class="small">( Non-detergent oils where delevloped around 1940 before adds where discovered/made. They are now considered 'obsolete' and should only be considered for use in 'non-combustion' type applications such as a small hobby reciprocating air compressor for example. They are SA and SB symbol I think.
)</font>
My understanding was non detergent oils should be used in combustion engines that have no oil filters. By using non detergent all of the crud goes to the bottom and is removed when the oil is changed. When a detergent oil is used the particles are kept in suspension and circulated around the motor. This is a good thing if you have a in line filter but causes premature wear when there is none. Don't know if this is true, but is what I have been told.Comments?
   / what is non-detergent oil #5
The only place I have seen N-D oils called out were compressors and pumps. No combustion gasses to worry about, and concern about foaming.
   / what is non-detergent oil #6
All reasonable answers, I think. Not being a petroleum engineer, I don't really know or understand everything about the differences, but in my memory and experience, everyone had to change to detergent oils when cars started using hydraulic valve lifters instead of solid lifters for one example. If you ran non-detergent oil, you'd soon have stuck lifters. And yes, early cars did not have oil filters and lots of crud settled in different places in the engines. I used to have one customer who wanted 30W non-detergent oil in his car at each oil change, but he also wanted a pint of Marvel Mystery Oil added at each oil change, so he was, in effect, using a high detergent oil, and his old Ford, with many miles on it, looked and ran like new.
There are many variations, but two basic designs of air impact wrenches; one that is lubricated with grease in the impact mechanism (front end) and one that is lubricated with motor oil (either 20W or 30W) and those with the oil in them recommend a non-detergent oil, so I used quite a bit of 30W non-detergent oil. And I still don't really know why they recommended non-detergent or what would happen if you used detergent oil instead.
   / what is non-detergent oil #7
For some old tractors (my '46 model Farmall, for instance) non-detergent was all there was in the beginning. A lot of people recommend against switching over to detergent except when the engine is being rebuilt. The idea is that detergent oil can cause accumulated crud lumps to break loose and clog oil passages, stopping oil flow to inner worknings and hidden mechanisms. Mine was rebuilt just before I got it, and I've taken that as permission to use high detergent 30wt. Good thing; its hydraulics require non-detergent because of foaming (which is probably why you've been recommended non-d) and 30wt because regular hydraulic oil is too thin for its old pump(are people telling you 30wt because you need something thicker?) and quality 30wt non-d is hard to find.
Wm
   / what is non-detergent oil #8
Bird:
Perhaps non - detergent oil is recomended as it will not have any heavy metals added??? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Egon /forums/images/graemlins/grin.gif
   / what is non-detergent oil #9
My old VW's called for detergents but then they did have a filter of sorts. It was a screen about twice as fine as a patio screen, does that count as filter or just a chunk catcher. For some reason right up into the 70's or so it was common practice to use non-detergent oil for your first use in a brand new or rebuilt engine. I remember my Dad buying Valvoline one time. The round cans always had red tops but one day he came home with a case with blue tops. The blue tops were non-detergent SAE 30 or 20.
Well its an old 1969 international hydrostatic drive and the hytran oil that has been used in it since day one is like 15-20 weight i guess and the hydro is warn out to the point when it gets hot it dont want to go very good. i know the hydro is on its way out and dont want to pay 3 grand to fix it yet or ever so i want to get a couple years out of it and was hoping thicker oil may help and if you find the post about (hydro warn out heavy oil yes or no) you can read what they say. I still would like more info before i put 15 gallons of non-detergent in there about what the oil is all about and why non deterg.
mike
GreatBear 1 Cu Yd Self Dumping Hopper (A44502)
GreatBear 1 Cu Yd...
2009 PETERBILT 367 40 TON CRANE TRUCK (A45333)
2009 PETERBILT 367...
AGT QA Pallet Forks (A44502)
AGT QA Pallet...
2014 International DuraStar 4300 Bucket Truck, VIN # 3HAMMAAN0EL767732 (A44391)
2014 International...
STORAGE FEES (A43003)
New/Unused 6ft Vibratory Roller Skid Steer Attachment (A44391)
New/Unused 6ft...
