Flail Mower what is it
   / what is it #1
smokehousebrown
Johndeer 40
i recently inherited a 1954 john deer 40 and the bush hog that came with it has a leak in the front seal. don't know the make or model. when i tore it down the #'s 30-102-10 are on the inside housing. the color it blue if that helps any. was bought in the late 60's. thanks for any help provided.
   / what is it #2
a new seal can be had with the ID of the seal housing, the OD of the shaft it goes over, and the deth of the seal housing ( seal thickness. )
many times you an measure all this off the old seal and shaft with a set of calipers if you don't 100% mangle the old seal pulling it out. if you do then it's caliper and depth gauge.. ( some vcalipers do ID. OD and deptch.. etc
soundguy
   / what is it #3
Yep as usual soundguy is correct.
Your source then would be a bearing supply house such as GBS (General Bearing Service) in Canada (believe they are in US as well).
Either way, yellow pages under bearings. (or on line)
2019 Peterbilt 520 Trash Truck (A55973)
2019 Peterbilt 520...
2008 Bobcat T190 Compact Track Loader (A55314)
2008 Bobcat T190...
John Deere 5075E (A53317)
John Deere 5075E...
2016 Cat TL1055D Telehandler (A55314)
2016 Cat TL1055D...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
