What is it Called???
   / What is it Called??? #1
hr3
Veteran Member
Mid. Coast Maine
7610 hst
I'd like to search for something but not sure what it is call... I hope you guys can help.. I'm looking for the "motor/ piston? used on a feller buncher.. the part that grips the tree before they cut it... I don't think it's a piston it's some sort of motor or something?? Thanks..
   / What is it Called??? #3
Valby is a common brand. Northeast Implement in Spencer, New York carries them.
Thanks,,, I'll do some searching now... bet there arn't cheap..
Your right JJ,, I finely found what i was looking for.. now I just need to find out more about them.. It was a hydraulic gear motor that I saw.. Need to check now and see if they are powerfull enough to run a grapple...
   / What is it Called??? #7
You want to use a gear motor to operate a grapple? A cylinder will be A LOT cheaper and easier to design.
kennyd,,, yepper more money but I'm waiting for my parts to come back from the machine shop.. I'm trying to design / build a duel action grapple,, two moving claws.. It might be easyer to use the motors than to try to get the pistons to articulate enough.. Not sure yet,,as soon as i get the parts I'll play with rods and pipe to see if i can make it do what I want.. The whole thing might be just a hair brain idea anyway..:confused:
2020 CASE IH 110N LOT NUMBER 206 (A53084)
2020 CASE IH 110N...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
