JRP
Platinum Member
I bought a used T190. The lower left corner has a bar graph gauge for what I think is hydraulic charge pressure, which always looks low, about four bars are black at 2800 RPM. The error report shows several faults on low hydraulic charge pressure.
What is hydraulic charge pressure?
How high should it be when normal?
What is good/bad ?
At what pressure should I worry about it?
What makes it low? I understand the sensor (sender) is a common problem.
Thanks for your help
What is good/bad ?
