what is grey market
   / what is grey market #1
Anonymous Poster
Epic Contributor
what is a grey market item? Is there any disadvantage to buying one? how do you determine if an item is grey market?
   / what is grey market #2
Grey market is when you buy a product in one country/region that was intended for purchase in a different country/region. For example, if you buy a VCR that was intended for use in the UK here in the US, or a tractor that was intended for sale in Japan. Manufacturer's often have to tailor their products for a certain market. For example, power supplies for a VCR, as well as the video signalling, are different here than in the UK. On tractors, sometimes the direction and speed of the PTO are different than they are in the US. I'm sure there are a lot of other differences, but these are just examples. One other that comes to mind might be the language of the owner/operator manual.
Aside from obvious incompatibilities like PTO speed/direction or voltage requirements, there is often no real problem with using the item. Many manufacturers, if you read the warranty closely, will void the warranty for grey market stuff. This is especially true for electronics. Depending on the manufacturer, it can sometimes be difficult to get parts/service for a grey market item. Some companies make a single model with a few variations for each region, others have completely different products for each region. It just depends.
As for how to determine what is grey, if you receive the literature that should have come with it, it will often point this out. Some manufacturer's that are frequent "victims" of this practice list models/serial numbers that are considered grey (I think Kubota does this on their web site). If all else fails, you could try contacting the US office for the company and see if they can help (if they don't have a US office/contact of some kind, this may be a good indication the item is grey).
Kevin
As applied to Kubota tractors the term means a model of kubota that was not intended for importation into the United States and not warrantied or supported in away by the dealer network. These tractors are easy to spot because they typically do not have the required safety items found on all legally imported tractors. The labels and manuals are usually written in Japanese not English, and the tires have very large treads intended for use in rice paddies. These tractors are used, and are difficult if not impossible to get parts and service for despite what the seller might be telling you. That being said, they are Kubota and might be a bargain. Buyer Beware
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
42013 (A51691)
42013 (A51691)
434669 (A48836)
434669 (A48836)
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
Ammco Brake Machine (A53424)
Ammco Brake...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
