What is a good Block Heater for Kioti CS 2420?
   / What is a good Block Heater for Kioti CS 2420? #1
Bannie
1955 Farmall 400, 2009 Bobcat CT122, Kioti CS2410
I have a 2009 Bobcat CT122 that is basically an older Kioti Daedong product, and that came from the Bobcat dealer with a factory installed block heater.
Now with a newer Kioti CS 2410, I'm wondering if there's a good place online to buy a block heater?
Any videos or instructions online on how best to install it?
Thanks for any advice!
   / What is a good Block Heater for Kioti CS 2420? #2
I was under the impression that zerostart manufactured the majority of the block heaters for North America. They are a division of Phillips and Temro.
   / What is a good Block Heater for Kioti CS 2420? #3
Most auto parts will have catalogue's that will have all the info to supply you with the proper heater.
Just have your tractor and engine info on hand when ordering.
If U go frost plug style then measure the diameter just to be sure.
AND
Forget the magnet style as all they do is heat the ambient air.
Thanks for the help and advice, everyone!
   / What is a good Block Heater for Kioti CS 2420? #6
i have put a hose heater on 2 tractors and at least one vehicle. they worked well enough for me.
   / What is a good Block Heater for Kioti CS 2420? #8
I have a Kat’s hose heater, need to install!
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
2008 Nautica International RIB 24ft Cat Boat (A50324)
2008 Nautica...
2020 KUBOTA RTV...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
