Quick Hitches What Implement(s) Would Fit this bill?
   / What Implement(s) Would Fit this bill? #1
lbaxterh
Lewiston, ME
JD 4066R
Having recently upgraded from a JD 4400 to a 4066 I have gone from one rear SCV pair to now having five rear SCV pairs plus power beyond. Last night my friend was looking at the tractor and said "What implement could you ever have that would use five sets of SCVs?" In my case two of them are used for top/tilt which leaves 3 sets.... but I still wasn't able to give him a good answer. My snowblower requires two sets of SCVs for rotation of chute and angle of deflector. I'm sure on much larger tractors the implements like harrows need a lot. But does anyone have any good answer I can give him for an implement for a 66hp tractor that would require 3 sets of SCVs (since 2 are used by top/tilt)?
   / What Implement(s) Would Fit this bill? #2
One run to the front to run the grapple - everyone should have a grapple. If one of your 5 is the electric with the thumb switch on the joy stick that is the one for the grapple.
2 for top and tilt.
Other two left could go on numerous things but stumpgrinder comes to mind - one swings other does up and down.
   / What Implement(s) Would Fit this bill? #3
Spray rig - boom height is one, boom fold is the other.
   / What Implement(s) Would Fit this bill? #4
a full hydraulic rear blade. Offset, angle, and tilt.
   / What Implement(s) Would Fit this bill? #5
Box Blade top, tilt and ripper extension/retraction.
   / What Implement(s) Would Fit this bill? #6
Top & tilt, a rear blade with angle, offset and tilt = 5 sets required. For larger blades, a set of gauge wheels, but that size blade would be to big for his tractor. I have come across a few guys that have needed 6 sets to be able to operate everything without connecting-disconnecting all the time. ;)
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2018 John Deere 333G (A47384)
2018 John Deere...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
2016 Nissan Frontier Extended Cab Pickup (A50323)
2016 Nissan...
2 piece Bale Ring Feeder (A50515)
2 piece Bale Ring...
