What Hydraulic Fluid for a Dynahoe 190?
   / What Hydraulic Fluid for a Dynahoe 190? #1
couchsachraga
Adirondacks, NY, USA
John Deere 4520 cab... formerly Yanmar 336D
Well, we've almost got the 2nd Dynahoe up and running...for this one we had to drain the hydraulic fluid out (when we pulled the engine) and it was rather black and dirty, so we're replacing all the filters and the fluid....anyone know what grade / spec hydraulic fluid to toss in this beast?
Thanks!
Adam
   / What Hydraulic Fluid for a Dynahoe 190? #2
I have a 140 B and I use DTE-24 mostly because I get it in 55 gallon drums from work when they drain the hydraulic oil out of an injection molding machine. I have had no problems.
   / What Hydraulic Fluid for a Dynahoe 190? #3
On assumption it has torque conv, an AW (anti wear with antifoam agent) class, probably around ISO32 for your winter temps.
Thank you...
It does have a torque converter, but has separate tranny fluid (and separate 90 weight for the gear box as well), so I went with straight hydraulic fluid as it appears to only run the hydraulics and not the drive of the machine, brakes, etc....
Thank you for the replies! She's up and running now...a few more things to tidy up and I may actually get some work done with her this summer....
Adam
   / What Hydraulic Fluid for a Dynahoe 190? #5
You are correct, the torque converter uses Dexron ATF, the transmission rear end, wheel drive/gear reduction all use gear lube and all the hydraulic functions like steering, brake booster, bucket and hoe movement are all regular tractor hydraulic fluid
KSI Conveyor (A53473)
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
1 pallet 19 Rolls 20X100 6-MIL Clear  Poly Sheetin (A53117)
1 pallet 19 Rolls...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
KUBOTA ZD1211 (A53084)
