What hyd fluid do I use
   / What hyd fluid do I use #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Hi. Newbie here. Could someome tell me what to get as far as which hyd fluid to buy?.
New tractor,so new tractor manual hasn't arrived yet and one of the loader lift cylinders is dripping fluid.Could this leak be from the tractor sitting a long time without use,seals hard etc?.I need to know which fluid to top off with until it stops or I get it fixed.It is a Farmtrac 300DTC and not hydrostatic drive.Thanks . /forums/images/graemlins/confused.gif
   / What hyd fluid do I use #3
What fluid you use depends on if your tractor has common sumps.. or seperate sumps. If seperate sumps, your machine may have either regular hyd fluid.. like aw32/46 in it.. or it may have UTF in it. Either should work.. but I wouldn't want to mix them. Call your dealer or the person who sold it to you and see what it was shipped with.
If it is a common sump system, more than likely a UTF that is compatable with the oem specified fluid will be fine.
Again.. you would need to know the oem fluid number so that you can check compatibility and equivalence.
Soundguy
   / What hyd fluid do I use #4
Soundguy
   / What hyd fluid do I use #5
Call the dealer. Speak to parts or service.
Bob
   / What hyd fluid do I use #6
Bob
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
