What Happened? Transmission Oil
   / What Happened? Transmission Oil #1
heymack
Home Sweet Home, Texas
Ford 8N, Ford 555A, New Holland TM120, New Holland TT60A
Greetings:
I recently purchased a Ford 555A loader backhoe with four speeds and a shuttle shift. Being the diligent type, I decided to change the oil and transmission fluid. Naturally the oil change went as expected, but something strange happened after I drained and refilled the transmission.
The operator's manual calls for Ford 41 transmission fluid so I went over to my nearest tractor dealership which happens to be a New Holland store. I asked for Ford 41 fluid and the guy wasn't sure what it was so he ran back to the service dept. and when he came back he told me that NH 410B is what I needed. So I drain ~ five gallons of old fluid, replace the filter and refill with ~ five gallons of the new stuff.
Now my hoe won't go! Yes, it was working just fine before the fluid swap.
I've checked and rechecked the fluid level (it's perfect) and run through all four gears and tried forward and reverse....NOTHING.
Anybody have any ideas? Did I use the wrong fluid? What's an equivalent to Ford 41? Could I have messed anything up?
On a related note, the hydraulic system calls for Ford 58. I'm a little low after replacing a hydraulic hose so I need to know what fluid to put in to bring it up to the proper level....yes, I 'm a little gun shy right now.
Thanks for your help.
   / What Happened? Transmission Oil #2
I'm kinda suprised they did not reccomend M2C134D type UTF oil..
Soundguy
   / What Happened? Transmission Oil #3
Are you getting the reccomended 2.1 jiggawatts to the flux capacitor? /forums/images/graemlins/tongue.gif
I really haven't a clue as to what it could be.
   / What Happened? Transmission Oil #4
</font><font color="blue" class="small">( Are you getting the reccomended 2.1 jiggawatts to the flux capacitor?
)</font>
Soundguy
OK, I figured everything out and also determined that I'm a moron. There are two fill holes in the cab floorboard, one for the tranny and one for the rear axle. I inadvertently dumped five gallons of tranny fluid into the rear axle sump. I don't know what's scarier, my incompetence or the fact that the rear axle sump was able to take five gallons.
Long story short, I got both refilled with the correct fluids and capacities. Now everything is working very smoothly as expected....live and learn.
Hey Soundguy, the NH 410B is the same as the M2C134D.
   / What Happened? Transmission Oil #7
I just hope that you didn't gall the Rendler Spindler, which would of course then cause the muffler bearing to fail.
   / What Happened? Transmission Oil #8
</font><font color="blue" class="small">( The flux capacitor is what makes time travel possible. )</font>
I'm quite familiar with the reference to the flux capacitor.. what I was asking was what it had to do with my comment about the M2C134D oil reference I made.
Soundguy
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2011 JOHN DEERE 670G MOTORGRADER (A51406)
2011 JOHN DEERE...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
