What happened to the JD 2720?
   / What happened to the JD 2720? #1
Talisker
Vermont
John Deere 2720
It's been awhile since I've looked at new tractors. I just realized that JD isn't building the 2720 any longer? What's up with that?
I'm just wondering if anyone knows why the models changed and why they did away with it. I'm guessing it has something to do with new diesel engine emission rules. I have a 2011 2720. It's been a great tractor.
Thanks,
Scott
   / What happened to the JD 2720? #2
It's the 2032R now. It is exactly the same as the 2720.
   / What happened to the JD 2720? #3
ohn Deere 2720
John Deere 2720 tractor photo
2008 - 2012 2000 Twenty Series
Compact Utility tractor
Series back: John Deere 2520
Overview
Engine
Transmission
Dimensions
Photos
Production:
Manufacturer: John Deere
John Deere 2720 Engine:
Yanmar 1.6L 3-cyl diesel
full engine details ...
Capacity:
Fuel: 7.1 gal [26.9 L]
Front axle: 4.1 qts [3.9 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at ends): 1433 lbs [650 kg]
Rear lift (at 24"/610mm): 1250 lbs [567 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Mid RPM: 2100
Dimensions & Tires:
Wheelbase: 65.2 inches [165 cm]
Weight: 1,973 lbs [894 kg]
full dimensions and tires ...
John Deere 2720 attachments:
front-end loader
backhoe
all 2720 attachments ...
2720 Serial Numbers:
- Serial numbers unknown -
John Deere 2720 Power:
Engine (gross): 31.4 hp [23.4 kW]
PTO (claimed): 23.5 hp [17.5 kW]
Mechanical:
Chassis: 4x4 MFWD 4WD
Final drives: spur gear
Steering: power
Brakes: wet disc
Cab: Two-post folding ROPS.
Hydraulics:
Type: open center
Pressure: 2421 psi [166.9 bar]
Valves: 2
Pump flow: 5.0 gpm [18.9 lpm]
Total flow: 10.5 gpm [39.7 lpm]
Steering flow: 5.5 gpm [20.8 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Battery:
Number: 1
Cold-cranking amps: 500
Volts: 12
John Deere 2032R
John Deere 2032R tractor photo
2013 - 2R Series
Smaller: John Deere 2025R
Overview
Engine
Transmission
Dimensions
Photos
Production:
Factory: Augusta, Georgia, USA
Original price (USD)
$18,595 (2013 )
$19,339 (2014 )
John Deere 2032R Engine:
Capacity:
Hydraulic system: 3.9 gal [14.8 L]
Front axle: 0.9 qts [0.9 L]
3-Point Hitch:
Rear Type: I
Clutch: wet disc
Rear RPM: 540
Mid PTO: independent
Mid RPM: 2100
Dimensions & Tires:
Weight: 1973 lbs [894 kg]
John Deere 2032R attachments:
mowing deck
snowblower
blade
front-end loader
backhoe
all 2032R attachments ...
2032R Serial Numbers:
Location: Right side of tractor frame, above and behind the front axle.
John Deere 2032R Power:
Engine (gross): 31.7 hp [23.6 kW]
Engine: 32 hp [23.9 kW]
Mechanical:
Differential lock: standard
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post foldable ROPS.
Hydraulics:
Type: open center
Capacity: 3.9 gal [14.8 L]
Mid valves: 2
Electrical:
Ground: negative
Charging amps: 40
Charging volts: 12
Battery:
Number: 1
Volts: 12
Hey thanks guys for the quick response. I noticed the hp is slightly different. Mine is 31.4 and the 2032 is 31.7.
The 2032 number series makes a lot more sense than 2720. I never did understand why they called it that.
   / What happened to the JD 2720? #5
Great investment for me too. Well worth the money, and I only use it for the FEL and a chipper.
   / What happened to the JD 2720? #6
The HP ratings on the 4520 changed 3 times and they never changed the name. How the manufacturers come up with their naming schemes and HP ratings is anyone's guess.
   / What happened to the JD 2720? #7
The new Deere number scheme is probably the best they've ever had.
5105 is not meant to be read as 51 05, but 5 105. 5 series, 105 hp.
New Holland is also using a system about the same, such as T5.105.
Kubota is jumping on the band wagon too, such as the (not yet released??) M5-091, ect.
Chery 12ft x 20ft Single Truss Steel Carport (A42745)
Chery 12ft x 20ft...
2014 PETERBILT 388 TRI-AXLE(INOPERABLE) (A45046)
2014 PETERBILT 388...
Lennox T-Class HVAC Unit | High-Efficiency Commercial Heating & Cooling System (A44789)
Lennox T-Class...
2007 FORD F-450 (A45333)
2007 FORD F-450...
2017 Deere 244K (A44501)
2017 Deere 244K...
Graco LineLazer IV Airless Line Striper (A44571)
Graco LineLazer IV...
