what grade of grease is 3-in-one aerosol spray grease
   / what grade of grease is 3-in-one aerosol spray grease #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
Hello,
It's time to grease the gears in the head of my Toro string trimmer .
According to the manual, I'm supposed to use a "good quality, lithium based #2 grease" for this.
I happen to have an aerosol can of 3-In-One brand white lithium grease, but the label on the can doesn't say anything about #2, or any other number.
Can anyone advise if this lubricant would be suitable for this application?
Thanks,
Tom
   / what grade of grease is 3-in-one aerosol spray grease #2
I would not recomend using the spray grease. It is probably a NGLI #00 or thiner grease (a semifluid grease). If you use a good quality grease on your tractors and vehicles it will most likely be a NGLI #2 and should work just fine for this application.
   / what grade of grease is 3-in-one aerosol spray grease #3
Like DP said.. a generic good 'tube' grease would work.. check what yuo use on your tractor.. it is probably nlgi#2 anyway..
Soundguy
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
